marcussly27
- May 6, 2015
- 142
Generally speaking, as flat as possible. parallel as possible, and equal-length as possible is best. But I'm not one in the camp of putting on frame drop brackets and drop pitman arms to make things as flat as possible at ride height (see items 1,2, and 4 above). I think your reasoning of what you might do in paragraph 1 is sound.Good to know, thanks for the feedback everyone. From my limited understanding of front end geometry, having the flattest possible drag link/trac bar angle is best since it limits horizontal movement when compressed compared to a steep drag/trac angle... am I correct there? This is assuming the drag/trac are parallel which mine obviously are not currently. Drops VS risers VS TRO vs TRU is a lot of preference but generally speaking the closer your steering is to the frame the better. So in my case, going TRO, removing drop pitman for stock pitman, and using a trac riser will net me the best geometry possible while also being more stable since drops can fail even though it requires heavy 4x4 to do so. Feel free to tell me I'm wrong here just trying to get a handle on this.
That all being said, can someone help me understand why someone would go with a steering linkage like the one I attached below that has the drag alllllll the way in the corner VS my set up that has the drag linkage much shorter? I understand the benefits of a heim joint for off roading/durability but I've noticed builders like ICON for example have this set up and I'm curious to the pros/cons.
Thanks!
Uhm..OK, but another reason for putting the drag link connection point as close to the knuckle as possible is to prevent the drag link from putting transverse loads on the tie rod.Generally speaking, as flat as possible. parallel as possible, and equal-length as possible is best. But I'm not one in the camp of putting on frame drop brackets and drop pitman arms to make things as flat as possible at ride height (see items 1,2, and 4 above). I think your reasoning of what you might do in paragraph 1 is sound.
I'm not a big fan of running the drag link all the way over to the pass side knuckle as shown in your pic. The intent is to give your drag link some length so there's less bump steer due to the longer drag link (I think that's what a vendor would tell you anyway), but in reality, the now much-longer drag link and trac bar length (and resulting angles variation) will cause more bump steer because they're moving in different arcs as the suspension cycles. This is noticeable even in the more common "Chevy 1 ton" conversions" (which I think ICON uses) where the drag link/trac bar are different lengths and often at differing angles. Monster Mike and Duff's have noticed this as well and ditched their earlier "Stonecrusher" kits (which were a copy of the Performance Unlimited/Bulletproof setups that started the heim steering setups in your pic above) for a BC-Broncos-type setup that use a saddle on the tie rod, to strategically keep the drag link at about the same length as the trac bar, and hopefully about the same angle too.
Todd Z.
Excellent point - totally forgot to mention that!Uhm..OK, but another reason for putting the drag link connection point as close to the knuckle as possible is to prevent the drag link from putting transverse loads on the tie rod.
The Early Bronco T-style tie rod is world famous for getting pretzeled by the drag link on right turns in the rocks. Especially when lifted, and when coupled with a shorter drag link and that 2WD F100 long sector power steering box.
It is from a "the tie rod/drag link assembly is stronger for rockcrawling" perspective that James mentions above. And depending on how everything is configured, the difference in lengths *may* not be enough of a liability that most people would notice it.Now I’m confused! So having the drag as close to the knuckle and longer then the trac is actually a benefit?
Yes, Lars helped me do the "Gary Yorston" mod to mine which takes the track bar almost all the way over the 'C' on the axle. Jim Creel's truck is done this way as well, and others here have done the same in intervening years. There are a variety of benefits to doing it.A lot has been done since then to install a longer trackbar to match the longer draglink. To varying degrees of success and difficulty.
Didn’t you do that to yours Todd?
Yeah, Chuck proved that didn't work in pretty fine fashion in his first Baja 1000 attempt.Just don't put the track bar mount on the radius arm cap. Looks like a good place. It will hold the radius arm as the axle is knocked out of the bushings. I know it was tried once.
