What knuckles do I have?
marcussly27
I tried finding photos online but didn’t get a good reference. Which knuckles are these? Thanks!
Dana 44 from what I can see. Are there any casting numbers on them?
More interesting are the brakes. That is not the normal OE or retrofit disk brake kit. Is that a wilwood kit?
Looks super clean and restomodded. Did you buy it this way?
M
marcussly27
Yes those are wilwood brakes. I bought it this way from my builder. I've had it now for a little while and am attempting to get the best front end geometry possible, so I'm considering a TRO set up which was the reason for the knuckle question. Dufftuff sells a kit that prevents having the drill the knuckles from my understanding. My end goal is to switch to TRO, get rid of the drop pitman arm and go stock there, then install the wild horses trac bar riser to get everything dialed in perfectly. The bump/torque steer currently drives me crazy. It's drives well but I want better and I like to tinker : ) If you have any thoughts on my game plan please let me know!
Best to find the casting numbers.
They look like standard Bronco to me though, based only on the use of a 66 to 75 drag link style.
I still say use a drop trackbar bracket even if it’s just a temporary test/fix. You currently have a way out of line trackbar and draglink because of the use of the drop Pitman Arm and nothing else.
Sure, you can go TRO and use a riser, but that doesn’t necessarily fix everything just by itself either. Once you go tie-rod over everything goes custom.
You’ll have to mock it up to make sure you can get the two bars back to parallel because messing with one almost never leaves you able to not mess with the other.
With TRO the riser almost becomes mandatory. But the two don’t necessarily put the bars back to parallel without some custom work on your own.
Good luck. Either way is viable, just different ways of achieving the same thing from a different direction.
bigjhoov
nobody
The TRO will make what you have worse. Stock pitman, track bar bracket, and a track bar riser on the axle is the way to go in my experience. From here it looks like a stock pitman would be an improvement over what you have now.
brewchief
I agree with dirtdonk, add a trac bar drop bracket first and see if it fixes it.
I believe that the simple trac bar drop bracket got a bad rap as wheeling got more extreme and the added leverage that it can create led to the original trac bar mounts being ripped from the frame, if you're a hard core rock crawler on 40s then it certainly is a problem. For the average bronco today that sees more street time then off road use it's not that big of a deal.
FWIW I have 3 1/2" deaver springs and have a simple trac bar drop bracket and a drop pitman arm and have zero bump steer that I can feel. Mine doesn't see a lot of street use but at the dunes going from full droop to full compression there is no feedback in the steering wheel at all.
Sent from my SM-T510 using Tapatalk
I prefer a track bar riser on the axle over a drop on the frame. Less leverage on the frame, that is known to crack with the drop brackets.
The drop bracket also interferes with a tie rod over (in full turn and suspension compressed)
The riser bracket limits up travel on the passenger side (and you should match it on drivers side), but that is generally a good thing as the large tires can smash up the fender opening if you compress the front springs that much anyway.
toddz69
The TRO/axle riser is more work than a drop trac bar bracket and dropped pitman arm, but it's better for a multitude of reasons:
1. less stress/leverage on the frame
2. less stress/leverage on the steering box
3. gets tie rod/drag link up and out of the way of rocks/obstacles if you're going to be doing any 4 wheeling
4. moves the roll center of the front suspension up to preserve (or somewhat preserve) the stock roll moment couple on the front end, which helps with vehicle handling (no one ever seems to mention this benefit).
And a comment on bump steer. Years ago I was reading some comments in a non-Bronco forum by Jim Frens, who is probably the smartest solid axle 4WD suspension engineer in the country, about bump steer. Someone was complaining about the 'steering wheel moving over bumps' test that we often mention as the test as to whether we have bump steer or not. He noted that test is often clouded a bit by varying degrees of system harshness in our steering systems, i.e. heim joints vs. TREs, T-style tie rods vs. Haltenberger linkages, U-joints vs. rag joints in the steering column, etc. He instead recommended that we drive over speed bumps or whatever we choose to exercise our suspension and hold onto the steering wheel and observe the following: as we pass over the bump, does the vehicle continue to go straight or does the bump upset the vehicle enough that it veers off course even if we're holding onto the steering wheel in about the same spot. If it veers off course, you've got bump steer issues. I observed this first hand a few years ago when driving my nephew's EB. I drove over some speed bumps and the truck literally changed course. Whoa!! In my personal truck, if you take your hands off the wheel and over the bumps, the steering wheel will do a quick back/forth rotation. However, if you hold onto the wheel and traverse the bumps, the truck travels straight and true. Big difference.
Todd Z.
M
marcussly27
Good to know, thanks for the feedback everyone. From my limited understanding of front end geometry, having the flattest possible drag link/trac bar angle is best since it limits horizontal movement when compressed compared to a steep drag/trac angle... am I correct there? This is assuming the drag/trac are parallel which mine obviously are not currently. Drops VS risers VS TRO vs TRU is a lot of preference but generally speaking the closer your steering is to the frame the better. So in my case, going TRO, removing drop pitman for stock pitman, and using a trac riser will net me the best geometry possible while also being more stable since drops can fail even though it requires heavy 4x4 to do so. Feel free to tell me I'm wrong here just trying to get a handle on this.
That all being said, can someone help me understand why someone would go with a steering linkage like the one I attached below that has the drag alllllll the way in the corner VS my set up that has the drag linkage much shorter? I understand the benefits of a heim joint for off roading/durability but I've noticed builders like ICON for example have this set up and I'm curious to the pros/cons.
Thanks!
toddz69
Thanks!
Generally speaking, as flat as possible. parallel as possible, and equal-length as possible is best. But I'm not one in the camp of putting on frame drop brackets and drop pitman arms to make things as flat as possible at ride height (see items 1,2, and 4 above). I think your reasoning of what you might do in paragraph 1 is sound.
I'm not a big fan of running the drag link all the way over to the pass side knuckle as shown in your pic. The intent is to give your drag link some length so there's less bump steer due to the longer drag link (I think that's what a vendor would tell you anyway), but in reality, the now much-longer drag link and trac bar length (and resulting angles variation) will cause more bump steer because they're moving in different arcs as the suspension cycles. This is noticeable even in the more common "Chevy 1 ton" conversions" (which I think ICON uses) where the drag link/trac bar are different lengths and often at differing angles. Monster Mike and Duff's have noticed this as well and ditched their earlier "Stonecrusher" kits (which were a copy of the Performance Unlimited/Bulletproof setups that started the heim steering setups in your pic above) for a BC-Broncos-type setup that use a saddle on the tie rod, to strategically keep the drag link at about the same length as the trac bar, and hopefully about the same angle too.
Todd Z.
jamesroney
Fremont, CA
Todd Z.
Uhm..OK, but another reason for putting the drag link connection point as close to the knuckle as possible is to prevent the drag link from putting transverse loads on the tie rod.
The Early Bronco T-style tie rod is world famous for getting pretzeled by the drag link on right turns in the rocks. Especially when lifted, and when coupled with a shorter drag link and that 2WD F100 long sector power steering box.
I run all of mine with the GM TRE and the pivot as near to the knuckle as possible. Once the drag link and tie rod are parallel and horizontal...the longer drag link wins.
toddz69
Excellent point - totally forgot to mention that!
Todd Z.
M
marcussly27
Now I’m confused! So having the drag as close to the knuckle and longer then the trac is actually a benefit?
toddz69
It is from a "the tie rod/drag link assembly is stronger for rockcrawling" perspective that James mentions above. And depending on how everything is configured, the difference in lengths *may* not be enough of a liability that most people would notice it.
Todd Z.
Putting the draglink over on the knuckle was simply a means to an end.
That end was not necessarily to get a longer draglink, but to accommodate a spherical rod end (“Heim joint “) assembly like pictured.
Somebody wanted Heims and that was the easiest way to get it at the time.
Probably still is.
Since it was not easy to stick a bolt through your new tie rod in the original location and they were already putting a through bolt on the steering arm for the tie rod end, it was natural to run the draglink over to the knuckle/steering arm as well.
Simply use a longer bolt and voilà. Done.
Any geometry “improvement” was a byproduct. Not necessarily the original intent.
A lot has been done since then to install a longer trackbar to match the longer draglink. To varying degrees of success and difficulty.
Didn’t you do that to yours Todd?
toddz69
Yes, Lars helped me do the "Gary Yorston" mod to mine which takes the track bar almost all the way over the 'C' on the axle. Jim Creel's truck is done this way as well, and others here have done the same in intervening years. There are a variety of benefits to doing it.
Todd Z.
Having said all that, there probably were two schools of thought.
Some did it just to get Heims so they could make their own steering and not pay more bucks for just more stock links.
Why not go beefier at the same time.
While some probably did it to get a longer draglink.
I wasn’t one of those early adopters, nor was I there for any of the latter discussions.
I was just an early observer.
Just don't put the track bar mount on the radius arm cap. Looks like a good place. It will hold the radius arm as the axle is knocked out of the bushings. I know it was tried once.
bigjhoov
nobody
Bump steer comes from different angles and pivot points in the steering/suspension components. You want the angles to be as parallel as possible, have similar pivot points, and on similar planes of travel. Todd can probably elaborate on this as an engineer. Yes, flatter is better but hard to achieve without things contacting during the suspension cycle.
As it looks now, I would suggest eliminating the drop pitman and try the stock one. It appears that would bring the drag link parallel with the track bar, and possibly remedy the issue.
toddz69
Yeah, Chuck proved that didn't work in pretty fine fashion in his first Baja 1000 attempt.
Todd Z.
