Whelp.. Squeal turned into engine torn apart
guidoverduci
NorCal
A few of you were helping me out with my engine squeal and determined the accessory setup was some sort of home made Serpentine setup... Here's the thread..
http://classicbroncos.com/forums/showthread.php?t=291420&page=3
I had taken it apart, then reinstalled and tightened everything down. The squeal was gone for a bit, but then I took it for a drive. As soon as I moved the steering wheel, the squeal returned. I also noticed while it was running in park, when I turn the wheel back and forth, the RPMs would fluctuate slightly?! I continued to drive a bit and by the time I returned, it was basically a continuous loud squeal. Tried to see if I could pinpoint and perhaps tighten the weird tie rod thing pictured in the thread above, but then that thing broke. Now, I've got it all apart and looks like I'll be headed towards the explorer Serpentine setup. While I've got everything apart, I'll be putting headers, new plugs / wires, and basically cleaning everything up (and getting rid of the huge heather hose). It has turned into a massive "engine beautification" project. I've got some stainless headers arriving shortly too.
At this point, I'm pretty much committed. Here's a few questions as I begin the swap...
I'll be purchasing the kit from the member on here selling the explorer setup. I'm assuming I'll need a new water pump? Recommendations?
A new alternator? Recommendations? I've got just basic stock electrical, with a mild stereo and painless harness.
The kit comes with a steering pump.
Harmonic Balancer? How do I tell what I have now? I've got a Serpentine setup already, could it be possible I've got the right one already?
And finally, my radiator is a passenger inlet. Do I need a new radiator with driver inlet for the setup to fit correctly? Recommendations? Thanks!
mtp71174
what year engine if it is a older 28 oz balancer then you need to rebalance the damper because explorers are 50 oz. I have seen someone use march lower pulley after cutting a water pump bolt boss to clear the pulley. A new radiator is the easy way to go bc makes kit to use the older radiator. Of course you would need to go to an electric fuel pump also. Yes explorer is the best and cheapest way. you can contact me at 734 818 922five for more info.
You'll either use the damper that likely comes with the kit, and have it re-balanced like mtp said. DamperDudes keeps them in stock on an exchange basis now I think.
Or if you have a stock Bronco damper now, which it does sound like, you can use a pulley like our #2502 on this page: Wild Horses Explorer Stuff and bolt right to your stock pulley.
For the radiator, it depends on whether you need to replace your existing one or if it's still good. If good, I would use the crossover tube that is readily available (WH #5047) and the like.
You'll need to mess with your upper too, and the Explorer stuff should come with the proper thermostat cover to clear the Explorer stuff.
Not sure of what brands might be "best" when it comes to water pumps and alternators, but you need to remember it must be for an Explorer and nothing else. Because nothing else works for sure (though some are close and may work, might as well get the Exploder version).
No matter what alternator you go with, it's not going to work with your existing Painless Black w/yellow wire if that's what is being used? It's too small and must be used with a heavier duty setup.
Easy to work out though. We have kits, others have kits, and you can make your own too with easy to find Maxi or Midi fuses, holders and battery cable. Use 6ga for normal runs, or 4ga if a longer run is utilized (such as around the compartment to keep it clean) or even an 8ga if it's only a short run.
But frankly, overkill is just enough with this, and even Ford uses 6ga and 4ga cables for their charging duties. So stick with that theme.
After all the work and nit-picky stuff is done, you're going to be pretty impressed with how it all functions I'm pretty sure.
G
guidoverduci
NorCal
Thanks fellas. I've got a good starting point. Just want to clarify the radiator part. Radiator works fine- would love to make it work. I'm just trying to see how it would work. I have a driver's side inlet water pump (I might have said it backwards in previous threads.. I'm still learning).. but basically the radiator is opposite of the stock and aftermarket bronco radiators I've seen. Lower hose on drivers side, upper on passenger. Is that crossover tube all I need to get this stuff to fit?
Then you're already set with the radiator, since the Explorer has a driver's side inlet. So your radiator having a driver's side outlet is already there.
Your existing hoses might even work. Won't know that for sure until it's all installed though.
904Bronco
San Martin, CA
So it looks like you will not need a lower hose relocation pipe since your Rad inlet is on the top pass side and your outlet is on the same side as the Explorer pump.
You might, as Paul said, be able to re use you existing hoses, but you will not know until everything is bolted up and in place.
The Explorer PS pump is far better than the one you have now. You will need an adapter for its discharge to convert it to an AN fitting (WH's). Hoses - many options, make you own with a kit, have a local hydraulic shop make it...
Water pump - any name brand New water pump will work. I have run O'Reilly's Murray brand pumps, or Napa's.
Alt - they are 130 amp, so Paul has already mentioned to use a larger supply wire/with a fuse, rather than what you have now. Buy new, which are all probably China assembled, or got to the wreaking yard and get a Ford one from an Explorer and have it gone through by a local rebuilder. The field wire plug might be different, you might need to ask for some help on that. New plugs with pigtails can be bought at Napa.
Since you have to change out the timing cover, consider changing the timing gear set. You will have to see how much slop it has in it when you get it open.
Plan for an oil change. Do you best to keep gasket scrapings from going into the pan.
Lower timing cover bolts have two alignment dowels that the bolts pass through. It can be challenging to get the cover back on, so you might need to loosen the front pan bolts to get everything together.
I tend to be AR, so wire wheel all the bolt threads and run a clean up tap in all the bolt holes. It makes things so much easier going back together.
Harmonic balancer, you are not going to know until you take the current one off. A local machine shop might be able to help you figure out what imbalance you have now so that you can replace with same.
Finally, upper timing cover bolts that go all the way through the cover have been know to have electrolysis occur. Which means they don't want to turn or snap off during removal. You will know how it will go when you start to remove them. It can be a no fun project...
Clear as Mud now, right... ;)
G
guidoverduci
NorCal
Actually, I think you’ve guys given me perfect info and plenty to work with. You guys rock! I was just checking alternators and it does seem like all the new ones are made in China and have a tendency to fail. Besides going to the yard, it seems like the only option.
I believe sandman’s exploder kit comes with the harmonic balancer. So is the idea to get the new balancer balanced to whatever engine I have? So if I knew what my engine came from, I could just send the new balancer off to get balanced to match my engine?
bronconut73
Waterpump from WH (Flowkooler) ($100).
New not rebuilt alternator from DB Electric on ebay ($100).
New not rebuilt a/c compressor from Visteon on eBay ($100)
The original ps pump is working waaay better than my Saginaw did.
I ended up grabbing all new idler and tensioner pulleys on eBay too. Pretty darn cheap. Well worth the effort.
Remember to lower and move back your ps reservoir.
You are really going to love Sandmann's Explorer Serp package. Every bolt is there. And you need them too. Not easy to find those funky bolts.
It works so good.
You will probably junk your original serp system once you see how good the Explorer stuff is.
It solved my grumbling Saginaw ps pump issue.
It solved my charging issues.
It solved my idling hot issues.
Air is ice cold.
And these accessories are so much quieter than my stock v-belt stuff too.
You are going to be really pleased Bud,
75MIKE
NE Washington
Do you keep your mechanical fuel pump or do you have to go to an electric with the Explorer front dress? thanks
G
guidoverduci
NorCal
I believe you go electric. The pros can chime in. I’ve already got an electric so I won’t have to tackle that.
Correct. In fact, you have no choice. Part of the extra space gain from the compact Explorer stuff is the low profile timing cover and water pump. Made so by eliminating the fuel pump eccentric and any space it left behind. No room for it any more.
For the engine, you don't need to wonder about the balance. You said it's a 351W correct? If so they were all 28oz and the Explorers were all 50oz. So yes, you will need to do one of the above processes.
1. Purchase a correctly converted, re-balanced Explorer damper.
2. Have yours re-balanced.
3. Use an adapter pulley on your existing damper, but only if it measures out as the same as a Bronco damper. Someone here can give you measurements and such. But does have to be a 3-bolt damper.
G
guidoverduci
NorCal
Copy all! I’ve got a pm into sandman for one of his kits. If he does supply it, I should be good to go seeing how it’s all from an explorer. Thanks!
904Bronco
San Martin, CA
With Sandmann it is about the weight for shipping, He can include the HB, and the ALT. But it raises the shipping cost, a lot.
You can, if you do the work, just replace the bearings in the Idlers and tensioners, a lot cheaper than buying a new unit. Press out and press in new ones. If they are even needed...
If you do not run an AC compressor, then use Gates Serp Belt :#K060825 which is shorter than the Factory one...
rguest3
I got the Explorer kit from sandman and it looks great. Not installed yet.
Parts Needed:
Water Pump - FlowKooler for Explorer
Fuel Pump: No Fuel Pump Boss on the Explorer Timing cover - Electric Fuel Pump Needed
Alternator - 140 Amp for the Explorer - Powermaster 47750, 57750 - Cable to B+ with Circuit Breaker
Balancer - 28oz., 302 stock replacement Balancer with WH Pulley is easy
Radiator Hose - Stock Radiator to Reverse Serpentine - WH has parts for this too.
G
guidoverduci
NorCal
Yep. 351W. I just want to make sure I understand this part correctly... My options are...
1. Have the explorer balancer from sandman rebalanced.
2. Have my current 28oz balancer rebalanced.
3. Buy one correctly balanced
4. Buy the adapter pulley and have nothing rebalanced (assuming current damper measures correctly)
Seems to me the cheapest / easiest is just buy the pulley. I’m trying to understand how these work. If the explorer is 50oz, I understand why it would need to be 28oz for my engine. But what would be done to my existing 28oz dampener to work with the explorer setup? And what if the current 351w dampner has already been rebalanced to work with this homemade serp setup, and will work fine with the explorer setup? And if it’s a balance thing.. how is just adding the pulley fix it?
Yes.
No. There's no need, because it's already balanced to your engine.
Yes. I think Damper Dudes has an exchange program, but you'd have to ask them.
Yes. If it's a 3-bolt damper now, it will bolt on. All you need to confirm is that it's got the correct offset/reach to line things up.
You could just take a chance, and if it doesn't work go the other route. But then that would be money wasted, so ask the members here if they've got some specs to compare yours to.
We might just need to see some pictures though. Because it's already a serpentine setup, you may have a separate pulley that's removable, or you may have an integrated belt pulley on your damper, which means that you have no choice but to change the entire damper. That's because we know for a fact that any existing pulley is not going to line up with the Explorer serpentine brackets.
You're forgetting that the pulley is not what's balanced to the engine, it's the damper that is important. And yours already works with your engine from a balance standpoint, because it's been running on your engine already.
The pulley is just a serpentine bolt-on to a regular damper that has either a bolt-on v-belt or bolt-on serpentine pulley already. The Explorer damper is 1-piece. The pulley and damper are one single unit. The "adapter" pulley that we sell is to make what is originally a v-belt damper with bolt-on pulley, compatible with the Explorer bits. It's all about alignment.
If your current serp pulley is removable, it's still "possible" that your current damper can be used with the adapter pulley. But again, we have to see what you have.
If you already posted a pic, great. If not, maybe you can get a good clear close up of the damper with, and/or without the current pulley.
And just to be clear, when we are saying "balanced" we're not talking about the traditional act of balancing a rotating component with the rest of the rotating/reciprocating components to achieve a better balance for better performance.
We're talking about matching two different designs that Ford use over the years to each other. Early-to-late and late-to-early so to speak.
Ford changed the "imbalance factor" of the 302/5.0 crankshafts in about '81 or so, from the traditional 28 ounce imbalance, to a 50 ounce imbalance. This, I believe, was to allow the manufacturer to make the internal crankshaft counterbalance bits smaller and lighter, to allow for more material in the block, or crank, or rods, or pistons, or something. All without having to change the entire design.
This necessitated using external balance components (the damper and the flywheel) with a heavier offset balance component to compensate for the loss of weight in the crankshaft, but still be able to balance out with the rest of the parts. Namely the 50oz offset, instead of the older 28oz version.
So your later model engine damper from the Explorer with 50oz imbalance crank, needs to be tweaked a bit to work with your existing older design 28oz imbalance crank in the 351.
I believe that they were able to keep the same ratings in the larger Windsor because there was already way more room in the block/crankcase area from the larger diameter main bearings and wider pan rail of the 351.
Don't take that all as gospel though. I'm just reaching into the ether to pull crap out of my hat. I know it's something along those lines, but I could have it all bass-ackwards or have added my own spin on it.
The point is just that your crank is different than the Explorer crank, so the damper and flywheel/flexplates must always match the crank that is in the engine. The three components, crank, damper, flywheel, are what must always match. Everything else is just along for the ride.
G
guidoverduci
NorCal
Got it. What threw me off was thinking I needed to have my current one rebalanced, I’m following with it all now. I’ll be diving in tomorrow and I’ll get some pics up for better visual with what I’m working with.
G
guidoverduci
NorCal
The carnage so far...
