Why Dana 60?
hossbronco
1 ton diesel doing peterbilt work 😂
I do believe you are right, ultimate torque rating on the 80 is more but in my un engineerin’ brain they are about the same.
Touché! 😂 I’m just making clear that the benefit of the 9” isn’t strength, it’s clearance while being strong enough. Think of it as the Floyd Mayweather of the rear axle world: pretty strong, but all kinds of clearance.
So why the 14 bolt over the D80? Weight? Simplicity? Cost? Maybe all of the above?
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
There are more than a few reasons for going 14b over D80. Easier gear setup, super easy to find in junkyards, shorter pinion length, higher pinion location, extra pinion support bearing, easy to narrow 4” just by swapping out hubs on non-ribbed versions, parts availability……..
And let’s not forget that my shaved 14b has just as much or more clearance under the center section as my stock 9” had, while being less susceptible to damage from bashing into rocks since the bottom is now 1/2” steel vs sheet metal. My driveline angle is also about 2 degrees less steep using the exact same driveline since the pinion is higher and I moved the axle back 1”.
Yeller
Yeller
Rogers County Oklahoma
All of the above. I’ll add clearance to the list along with parts swap ability. Just about for what the locker costs for an 80 you can build a 14B. The the single potential positive for an 80 is the potential for OEM 37 spline axles, I’ve personally never found a set lol.
PNW
Custom fabbed 9" housing weighed single digit difference than a 14 bolt.- I will double check my build thread.
Flange to flange and grd clearance was almost identical.
I'll try finding those #'s too- bet they are buried. Who's that guy that wrote that BOOK LONG thread anyway??!! :)
PNW
Wow! The difference is comical! You have me leaning towards a 14 bolt rear now, and I’ve been dead-set on my 609. Still like the 609 front.
I was going to go 609 but I got a screaming deal on a '79 HP60 but what really convinced me was grenading 9" parts. Why install more of the same?
hossbronco
I appreciate y’all’s patience with me. I’ve done a ton of research, and didn’t decide on a 609 rear lightly. Some of it was a desire to work within the Ford design, and some of it was the thought that if it’s good enough for KOH, I’m sure I can make a HP10 work. I could even carry a spare third member to share between front and rear. The 9” @nvrstuk blew up didn’t work because he used the inferior True Hi9 with the inferior standard ARB. But mine would be different because I would use better parts and not wheel it as hard.
The funny thing is the truth was staring me in the face this whole time, and it took the photo @nvrstuk posted to snap me back to the reality that @Yeller touched on on page 1. And I already knew this, but the reality is that it isn’t good enough for KOH, at least not in the form I’m going to run it. Whatever my axle design, a selectable locker front and rear is an absolute must. I was going to run a 609 rear with an ARB. As @Yeller said, this is the weak point, and the KOH folks are running a spool.
So I apologize for hijacking the thread a little, but I want to thank you patient guys for saving me thousands of dollars and tons of hours, not to mention an embarrassing tow back to the trailhead (or worse, back to the mall after shifting into 2nd at 6,000 RPM on asphalt). I’m now squarely in camp 14B rear.
hossbronco
Now, if y’all don’t mind helping me a little more, I’m moving back to more on topic. I still like the 609 front compared to a D60. I was going to run an HP10 with a 4” Spidertrax housing, ARB, Reid Racing Super Kingpin knuckles, Wilwood 6 piston calipers, 40 spline gun-drilled Big Bell RCV shafts, Super-60 unit bearings, and a billet 1480 yoke. I’ve never seen quite this setup before, but it is something I’ve pieced together in my mind. It certainly seems fairly sturdy, but explain to me why a ProRock 60 or similar would be better. Maybe the ARB is my Achilles heel again? The 10” R&P is stronger than the D60 as I understand it. Or maybe I should just go with the 14B front @1969 just posted. I wish it were high pinion.
PNW
Hoss- you are thousands of dollars ahead... I have over 100 more HP now and at least 125 more TQ than what I had when I grenaded all that stuff. Also running 40"s vrs 37"s before. Like I said tho, most of my carnage is/was all low speed crawling stuff.
You'll like the 14.
I'll let others answer your specific Q's on front options. My frt end is my weak link at this point and will be interested to comments on "somewhat bullet-proof". :)
Reno, NV
https://eastcoastgearsupply.com/i-19763386-gm-14-bolt-front-axle-shaved.html
Also east coast gear supply builds them.
I only put the 05+ super duty axles on my bronco because it was just a tub and frame, and because I want to go to the rubicon and bring food and drinks in the precious limited cargo space not spare parts for the wimpy stock 44/9. Oh and because they’re cheaper in the long run since everyone on the west coast wants a ridiculous amount of money for the stock axles now, and then having to build them.. and they still wouldn’t be as strong. yeah I’m good.
Yeller
Yeller
@hossbronco no worries, this has been the best axle conversation I’ve ever been involved in. Lots of soul searching for all of us, sharing experiences and most importantly we’re still discussing and saving a brother enough cash to make a difference in his wheeling/traveling budget.
That front axle you have spec’d is definitely a phenomenal axle. I don’t think you’ll ever brake it and I do mean ever but is it necessary? Imo you’d do just as well with a 60 with your choice of 300m shafts and a guaranteed dependable ARB. That would also mean it’s built with more off the shelf parts which lowers the cost, and makes it life time serviceable. Now would I be concerned about GearWorks or TubeWorks even Hi9 going out of business? Not really, they are well established and have a dedicated following. But that’s not to say they won’t develop the next latest greatest thing next year and in 5 years your diff parts are completely obsolete, making it in repairable. Just twisting on the thought process of how over built is over done and could that thought energy and resources be reduced and be just as happy with the end product? I l’d rather see you dive in, finish the truck and let’s go wheeling.
I do agree that what you have spec’d is absolutely the best of the best and if it is what you want, have the resources and can get it done by all means build it.
hossbronco
Thanks. I’m not so worried about future proofing the 609. 10” gears will always be around (or at least 9”), and I don’t mind switching to the latest and greatest third member every 15 years. The biggest risks are ARB discontinuing the competition ARB and a car wreck or other unfortunate accident breaking on of the knuckles. All the other parts are relatively replaceable or at least interchangeable. I could carry a spare third member for an emergency trail fix if needed. I just don’t see myself breaking the knuckles under normal use, at least without completely destroying my rig.
My real question is how will the 10” ARB compare with the D60 ARB? I’m pretty confident in everything else.
You’re right about the Dana 60
On a side note, going to a 14B rear 609 front will push me to abandon plans for 5.43 gears now that the axles don’t match. I would be running a 5.38 rear and 5.43 front. Conventional wisdom is that your axle gear ratios shouldn’t be more than 1% different on the road, and mine would be just under 1%. I could probably get away with it, but a 5.13 rear and 5.14 front is much closer. It’s probably for the best anyway now that I’m running a 7.3L Godzilla (along with a 6R80 and Atlas Pro 3.0) and I think the new gear ratio will work nicely, as I know @nvrstuk would attest to.
okorangebrnco
Steve just had to start this thread.... A 39 minute phone call last night and the 9inch debacle continues.
Yeller
Yeller
5.43 and 5.38 are plenty close enough. Much closer than 3.50/3.54 the factory uses.
As for strength comparison between the ARB’s no real clue other than 60 ones are highly proven reliable and serviceable if ever needed
PNW
Hoss- you saw my pics of the 14 bolt ARB and the 9" ARB. I run a D60 ARB up front and it is much larger than the 9" ARB but nowhere near as large (aka- less meat) than my 14 bolt. The Comp D60 ARB is so much larger than the Comp 9" ARB that personally, I'd never go with a 609 up front comp ARB or not as there's not enough meat. The Comp style 9" is strong but go with a Comp style #RD166 D60 ARB and never look back.
Here's what I hear you saying in this thread. You want about 1% chance or less of having drivetrain breakage ever. If you're willing to go with the strongest knuckles known to man :), but compromise on the ARB because of the want of a 609 then I need to ask- is this what you want for reliability or just because it's what you've had on the build list for a long time? (Just asking as I need to hear this once in a while too)
Here's the facts as we've been discussing (correct me if I'm wrong).
Almost bulletproof is the 14 bolt front like posted above from eastcoast gear
Next step down is the D60 like Steve and I and others have mentioned,
Next step down is the 609.
Just trying to help as I'm sure your head is full. :)
jamesroney
Fremont, CA
RD99 = RD249CE = 9 inch = 28 lbs
RD35 = Dana 60 = 43 lbs
RD114 = 14 Bolt = 46 lbs.
Just sayin...
PNW
Guess when I used the word "meat" to describe the 14 and D60 it was accurate (for once). :)
RD166 comp model for the D60 is 44# on one ARB chart and 43# on another.
