Windsor flywheel bolt pattern dimensions
Digger556
I need accurate dimensions of the crankshaft to flywheel bolt pattern. Is there a print out there with this information before I start tearing something apart?
Dang, I've seen a nice one comparing various engines online somewhere. But I bet I didn't save it at the time!
Typical...
I'll dig around though, just in case.
Might ask Eagle or Scat. I bet they would be willing to tell you what the bolt spacing is on the cranks they make.
I do know it is NOT symmetrical. The bolts are spaced oddly so it only goes on one way, so the balance is in the right spot.
Digger556
Digger556
I found this on the GT40s forum:
6 holes to suit 7/16" bolts on 3" PCD ---One hole at 64 deg (ie 60,60,60,60,56,64 ) approx. opp the counterweight looking from the clutch side of the flywheel.
Maybe someone can confirm
