Wiring help
Post up your page of the Centech instructions that I saw earlier. That will help to, I think, essentially, do what was said. Except I didn’t realize there were two purple wires coming out of the driver side.
So you don’t need to cut the start NS wire and splice it into the neutral safety switch. That was with a different generation Centech harness.
This one changed so that you have one wire marked “start” coming out of the driver side, that goes to one side of the NSS.
You have another purple wire coming out of the driver side that says “start NS” and that goes to the other side of the neutral safety switch.
Then on the passenger side, safely tape up the end of the purple wire marked “start” and tuck it away.
Only the wire marked “start NS” attaches to the S post of the starter relay.
Done.
Stevenb
Stevenb
Spokane Valley, WA
Sorry, I don’t remember how that used to go exactly. But like I said, it’s been awhile.
And just to bring it to the top for discussion, maybe now is the time to upgrade to a 3G alternator.😉
I’m just getting ready to do the serpentine conversion. Thanks for all of the info on that. I have to look more into grinding the cam bolt, the cam pin and the fuel pump eccentric. I haven’t found anything super clear about that.
Then I need to look more at the charging wire. I was thinking of going with the wild horses wires and fuse holder. Is that the best route?
I went yesterday to my local pull n save. They have 13 explorers with brackets and such. Only like 5 have the full 5.0 l setup. I got the brackets and a new 4g alternator. I think it’s 4g anyway. It has the black case back. Is there a way to tell for sure? It and the bracket have the narrower double bolt pattern. They have some with the wide pattern also. I have several parts on order from rock auto. I got a timing cover, metal fan, clutch and new idlers and such like the guy that just made the YouTube video showed. Is it necessary to go with a flow cooler water pump? I have a standard rotation flow cooler now and it helped my cooling a lot. Just not sure if I need the explorer flow cooler.
Can the explorer power steering pump handle hydro boost and 37’s? Or should I keep my Saginaw high pressure one and get the bc broncos or wild horses bracket?
I need to go back and get the water pump pulleys too. There are 5 of those but I didn’t have the tools to get them. I also snagged 5 of the 175 mega fuses.
I think I have the rest of the alternator wiring straight in my noggin. I did get the short chunk of harness with the alternator.
Sorry for so many questions. You guys are such a huge resource. I can’t tell you how much I appreciate your help.
ntsqd
heratic car camper
Upper SoKA
IMO the Explorer front cover and water pump are what Ford should have done for the 221 way back when. Than all of the small blocks would have had it from the start. A premium water pump is a good call. I wish that Stewart Components had a specific listing for the Explorer. I'm not sure that the plate on the typical Flowkooler pump (their original claim to fame) will buy much improvement.
Do you pull the Explorer specific harmonic balancer or are you going to order a new one from The Damper Dudes?
I don’t remember anyone ever talking about that. Usually, if I remember correctly, they just replaced the dowel with the shorter explorer version. Same for the bolt? Same for the timing gear?
There’s probably no “best“ in this case. But it’s one of the simpler ones because it’s all ready to go.
The lengths are reasonable for most installs. As long as you haven’t done a battery relocation or something like that.
If it’s from an Explorer of that vintage with a 5.0 L, then it’s a 4G.
Probably not, but it shouldn’t matter. If it bolts to an explorer bracket, then it’s an explorer alternator and is a 4G.
The 4G will be missing the white with black stripe stator wire, and will not have a connection in the side of the case near the main connector.
Not sure what you’re referring to here. As far as I know, there is only one design Explorer bracket, and only one design Explorer alternator.
No, but…
They are never absolutely necessary. However, they are a very nice upgrade and a quality part in general. I’ve used them for almost 40 years and had nothing but stellar luck with them. Even back when they just use that plate.
They should all now have their own design, custom impellers. Very snazzy and fancy. But I’m not sure they’ve quite gotten their heads out of their butts yet, regarding the clearance on FORD engines.
Personally, I would try to explore pump, or maybe one modified by Lee. But since you already have that one, it’s hard to say. I like the plumbing on the explorer set up.
So all those used the mega fuse instead of the fusible link then? Pretty cool. Did you happen to know what your models they all were?
That will save you lots of time I think. Once you get your head around it, the wiring is pretty simple.
Wait, was there a question in there?😉😁
Stevenb
Stevenb
Spokane Valley, WA
I was thinking of doing the damper and pulley from wild horses. It’s about the same cost wise.
Stevenb
Stevenb
Spokane Valley, WA
I don’t remember anyone ever talking about that. Usually, if I remember correctly, they just replaced the Dow with the shorter explorer version. Same for the bolt? Same for the timing gear?
No, but…
I believe the mega fuse was on 98 mercurys and the same year explorers. There were a few I left just so I wasn’t taking all of the goodies. For all I got, alternator, brackets, pulleys, metal fan and fan clutch, mega fuses, etc it was $130.
904Bronco
San Martin, CA
Personally, from what everyone has written here... Keep the Sag pump if you have a ram and 37" tires. (Looks like you have hydro boost too)
The original Explorer PS pump starts gets taxed with tires bigger than 33".
ntsqd
heratic car camper
Upper SoKA
I agree, if you have a pump that is working now and there's a way to adapt it to the Explorer front dress then I'd go with that. The only caveat would be if the current pump config is not a remote reservoir and the adaption requires one. Then I would look at all of the options first.
Great price!
Yeah, the only two mega fuses I’ve ever saw were on Mercury Mountainwere. I couldn’t believe that FORD would do them different from the Ford Explorer, but maybe they didn’t, and it was more of a year by year thing.
