Yoke Problem / Question
Tedster100
Chairman of the Bored
I cracked a u-joint at the rear diff a while back and now I'm going thru them like candy - maybe 20 miles & they're done. After talking with Tom Wood (excellent guy by the way!) he said it sounds like the wrong size cap causin mid-alignment. Upon closer inspection I found that one of the keeper tabs that is on the pinion yoke is broken out and is allowing the u-joint to slide to one side in the straps causing failure.
I have another yoke from a spare 9" but I'm thinking I'll need to have the pinion re-set if I loosen the yoke but & re-install. Is this the case or can I just swap them?
JWMcCrary
You will have a lot of responses saying you need to swap the crush sleeve and redo, however I done exactly what you are asking numerous times and never had a problem.
bmc69
Same here.
PaveBronco
Same here, I just marked the starting point and counted revolutions until the nut came off. The Yoke spline was the same length, so I just trightened it up until the nut was back in the same place. A year later I put in lower gears and just to see how the nut thing worked I checked the pinion drag and was still within spec's. So yeah I'd just swap it.
But you can also pull the third Member and carrier, put the new yoke on and work the preload that way.
Apogee
Tangent, OR
If you're nervous about it, you can always get a new crush sleeve, however I've never had an issue with it either way. My latest 9" will get a solid spacer, so that's an option as well.
70_Steve
Old Guy
Why pull the 3rd member/carrler. Just remove the pinion assy. The pinion depth is set with shims between the housing and pinion support. The yoke and preload have nothing to do with pinion depth. The pinion support is sealed with an o-ring, which most of the time you can reuse.
PaveBronco
Only have to remove the carrier because the pinion brearing preload has to be done with the carrier out, its like 10 or so inch pounds to rotate the pinion at the yoke. Its just to get the correct preload on the pinion bearings and keep them from moving around or burning up if the preload is too much. Solid spacers instead of the crush sleeve is the way to go.
JWMcCrary
You don't have to remove the carrier, you can, but it's not necessary. You do it with the pinion assembly out and not have to mess with the axles.
PaveBronco
You're right, thanks for the correction JW, I only ever deal with them when the whole thing is out for gear swaps. Makes for torqueing the pinion nut a breeze.
