Sorry too, that I forgot to post the pic!
So here is one (image #7 in your file) showing the Green (trigger?) wire connected to both the large stud and to the small connector:
My guess, just from my limited knowledge, is that as soon as you connect power to the battery, your starter will start to spin.
I've seen starters that had jumper wires between solenoids and motors, but never one quite like this. That is, unless you can find a third connection point for the trigger wire and the Green wire on yours is just for other duties.
If there is no other connection point, then my guess is that your Red wire should replace the Green wire at the small connector. And that the Green wire should be eliminated.
Any word directly from Mean Green yet?
