- Joined
- Jun 4, 2002
- Messages
- 37,068
If you want to get into rod angles, I like long rods.
The 289 was a better running engine than the 302. The 302 should be a better engine with more cubes and longer stroke, but I have always felt the 289 was just a better running engine. I know others that like the 289 but can't say why. This is in stock 2V flavors all they way into the high compression performance stuff.
Part of the 351W development was to make it a long rod motor. Hence the raised deck.
My last 351 (built just before all the affordable stroker kits came out) was built stock stroke but long rod. That was one happy engine.
Get into high end, make all the parts what works best and not to a price point or package constraints and you will find long rods are king. Short rods are a manufacturing constraint of trying to package a long stroke engine in too compact of a package.
Talk with real engine builders (not just assemblers of a box of parts but people who actually make engines out of big blocks of metal, a lathe, and a mill), people who only use an existing engine due to class constraints, long rods are the preferred design. I know a real good engine builder who makes stuff for Bonneville, late 30's straight 6 Jimmy engines that get 4 to 7 main bearing conversions (bolt the crank into the girdle then bolt the girdle into the block). Just to stay in the prewar engine class. Sorked for Gurney in the 60's. Factory Porsche race team in the 70s and 80s. Got plenty of lecture on why a 2:1 rod ratio is really good.
Or maybe the coworker who worked for the best damn garage in town (Smokey Yunick) that I just got a late 80's GTP wheel from (going to be an end table in the living room as soon as I clean it up and get a glass lid made for it).
I've been around too many really good people to ignore there advise. I'll do long rods as much as I can. And a 351W block gives so much more room to run a longer rod.
