Bronchole
351W EFI conversion, what else do I need?
I have been collecting parts for converting my moderately built 351W to Ford EFI for a few years now. I have been running a Holley 4DI setup for over 15 years (transplanted from my FSB) but I’m thinking it’s time to try the Ford EFI to squeeze out that last bit of power I know is in there.
Current motor/driveline and other useful info:
- Full roller 351W (9000 miles on it)
- Trick flow heads
- Cam was supposed to produce ~400hp and 400 ftlb of torque. It is a custom grid with EFI in mind. If it is crutial I can probably dig up the cam specs.
- 10.5:1 compression
- MSD Billit distributer with TFI IV module mounted to distributer.
- Accell E-core replacement coil
- 4R70W
- Dana 20 with Tera low gears
- 4.86: gears
- 35” tires
- BCB shorties in to 2.5” tube going in to a single Magnaflow (longest model) with 3” out the back.
- O2 bungs in each side of the exhaust about 10" or so down from the header flanges
- Modified Explorer front dress.
- Taurus fan on a 4.0 Explorer radiator.
- 1” body lift
- Fiberglass hood with the big raised area in the center
- HD West Coast Broncos motor mounts
- No fender wells
- Hydroboost installed in the clutch position
Here is what I got for the EFI convesion:
- I have all of the efi stuff from a 93 Mustang except the wire harness and computer. The throttle body that came on this is a Edelbrock BBK 3828 70mm model.
- I have a 92 Mustang harness that I will be reworking (electrical work doesn’t intimidate me at all)
- I have a lightning lower. It has the sensor on th e#5 runner in it from the Lightning. (I also have a 351 truck lower)
- I am going to be picking up an Explorer upper this week from a local fellow Bronco owner. (thanks Robert)
- I have a TwEECer RT that I picked up for a great price a couple years ago.
I know I need:
- Some form of an EEC computer. I would prefer it if the computer was capable of at least limping the motor without the TwEECer installed.
- A pair of oxygen sensors (I already have bungs installed in the exhaust)
- Any sensors that are not mounted directly to the engine.
- High pressure fuel pump
- 24 lbhr injectors
- I suspect that I will need an intake spacer to clear the upper intake over my very tall valve covers. Weather it clears or not I intend to run as tall of a spacer as I can fit to promote torque.
I am also intending on installing a speed sensor from a mid 80’s Bronco.
Other useful stuff I have:
- I have a wideband O2 sensor setup that I could install, but if I am going to run 2 O2 sensors for the EFI I will need to have another bung installed in the exhaust.
- A good understanding of how EFI works (15 years of experience and reading with my 4DI)
- Dash mounted vacuum gauge
The fuel system that is currently installed in the Bronchole has the 2 tanks plumbed in to a 6 way valve. The valve feeds in to a Carter low pressure pump that feeds a fuel filter. I have modified the fuel filter to recirculate a small amount of fuel back in to the return line (like the BCB accumulator). The filter output runs to the Holley in-line 15 PSI fuel pump. 3/8 SS line delivers from the pump to the back of the intake manifold. A 3/8 SS return line runs from the back of the intake manifold to the T at the fuel filter and then in to the 6 way valve. I intend to replace the Holley fuel pump with a similar format unit (like what Ryan has in his writups) and replace the rubber lines with EFI rubber lines to handle the increased pressure for the new EFI system.
I have read all the pages in Ryan’s site and have been watching EFI threads on here for years. I think I have a good understanding of how EFI works. I am looking for any advice related to my application.
- Trick flow heads
- 4R70W
- 4.86: gears
- 35” tires
- 1” body lift
- No fender wells
I know I need:
- 24 lbhr injectors
