393W Transformation Thread
HoosierDaddy
How much was the boneyard motor , if you don't mind me asking?
Also , where is the F4te casting located on the block ?
E
EricLar80
I paid $300; was hoping to get it for $250. In Los Angeles, the running ones seem to start at about $550, and a block goes for a few hundred alone. So I think I got a decent deal.
The casting number is located on the side of the block, up by the starter. You almost have to look from the bottom of the motor to see it.
Eric
mattt
On half off days at the pyp, you can score a complete engine for under $200 + your time to pull it. Only thing is you need to check it thoroughly since who knows why that vehicle is in there. I've been seeing quite a few F4TE 351's in the yard lately.
E
EricLar80
I looked for a while at the pyp, but didn't have too much luck. I decided the extra $ was worth just going to a place and having them drop it in the back of my bed with a forklift.
Note to self: 351w placed at rearmost section of Tacoma bed makes steering responsiveness almost nonexistent... :p
Eric
needabronco
Prescott/Farmington
The pick and pull I frequent sells long blocksfor $175, but you do all the work to get it out... There's something to be said about haveing them pull it and drop it in your truck for an extra $125! I'd say that's a decent deal. There are yards here that would have charged you over a grand for a long block and the pan and valve covers would be full of dents and 3 years of dirt and rust...... All yards are different!
mattt
I agree....for $125 more it's not worth the effort, especially if you have to pull one at the pyp out of a van which is where I've been seeing the most late model 351s. I would also think when you buy an already removed and palleted engine that they would do a cursory check to make sure it doesn't have a whole in the block or is locked up. For ~$175 here, you get a complete engine with all accessories.
E
EricLar80
Oh jeesh, here they want to nickel and dime you for every accessory.
Case in point, while we were making the deal he agreed to throw in the flexplate, but when it came to being loaded in my truck, it wasn't there. Long story short, we went back and fourth on the definition of a flexplate/flywheel and eventually it came down to him looking it up online to see what it was. Apparently "they call that a flywheel even if its hooked to an auto transmission" and "they call the cover to the transmission a flexplate." %) Well guess who has a flexplate sitting in their truck bed in picture one. ;D
I don't even know if I can use it for the 4r70w, but I think I can based on the size (11.4", hole to hole) and number of teeth (164).
Well, I leave China today, so maybe I can get more work done on Sunday afternoon. BTW - I do not recommend eating pigeon. It is very gamey; and anytime they give you gloves before you eat something, its gonna be super greasy... :p Wish me luck on the ~15 hour flight.
Eric
mattt
That seller obviously doesn't know what a flexplate is. The places down here will nickel and dime you as well....as an example....you are better(cheaper or the same) to buy a complete Explorer 5.0 vs. bringing the front accessories up to the checkout window. Each part rings up separate and from what I remember it's the same or close as a complete engine.
If that engine was in front of a larger trans(c6, E4OD), which it most likely was, that flexplate won't work. It has the wrong offset for the 4R converter. It will bolt up but it will not allow any clearance for the converter and will take out the trans pump within seconds. A stock Bronco flexplate(76 C4 for example) has the correct flexplate for your app. 164t, ~14.xx" dia, ~11.xx" pattern, 28oz, small trans offset.
E
EricLar80
Bummer, but thanks for the info. I'll have to compare the flexplate offset to the existing one I have. Too bad the weight is incorrect (50oz now), but maybe I can fix that when I get the rotating assembly balanced.
Eric
E
EricLar80
(click for larger images)
UPDATE: I finally got the engine disassembled this past weekend and bought an engine stand to put it on. The stand is made by 'Blue Point', I guess it is a snap-on secondary brand or something? I like it because it has 4 wheels instead of 3. Got that for $60, used.
It was raining pretty good in California over the weekend, so it was a prime opportunity for me to have some personal time at the local do-it-yourself car wash. The warm water, high pressure washer and engine degreaser stuff they supply worked very well on the greasy engine. I brought it back and quickly dried and sprayed WD-40 on it to prevent rust from forming on the machined surfaces:
Since I am going with the 393W, I am not too worried about the crank, but I was interested to see what the bearings looked like. The crank and cam bearings look ok from what I can tell:
No bluing on the caps for the crank bearings, and they weren't spun, so that is good news. They'll all be replaced:
The pistons and rods all look to be in ok shape, although I will be getting new pistons.
I did find that the previous owner of the engine was not too fond of oil changes, as there was a ton of thick, black slime in the oil pan. From what I can tell, the block faired well. I am going to be sure to clean the oil pick-up tube really well, though.
I also found a great deal on some 351W Eagle H-beam, stock length, forged connecting rods ($300 for the set, vs like $550 on Summit). PM me if interested. I was thinking of reusing mine, but that may be too good of a deal to pass up. ;D
Eric
E
EricLar80
Can someone weigh in on the Roush/Dart 200 heads? 2.02/1.94 valves. Too big for our application and this motor?
Quick replies would be great!
Thanks,
Eric
E
EricLar80
There has to be someone that can chime in on cast iron heads with 64cc combustion chambers and 200cc intake runners and 2.02/1.94 valves?!?!?
Eric
Nightstick
Bronco guy
I can only tell you that the heads on my 351 aren't far off that. 190cc 2.02/1.60 64cc chambers... I think they'd be fine on a 393, but I'd check the compression ratio since they're cast iron.
E
EricLar80
Thanks, Nightstick. 64cc heads and 22cc dish pistons puts it at about 9.3 for the compression ratio. What are you running for your CR? Do you have aluminum or cast iron?
I ended up buying the heads off craigslist - found a deal I couldn't pass up even though it will be a while before I need them. The heads are new, never installed, and they are fully assembled with dual springs, SS valves, pushrod guides and rocker studs included. All for $680; about the cost of, or a little more than, 1 new cast iron head that is fully assembled with similar specs. ;D
Eric
Nightstick
Bronco guy
I'll be at 9.7:1 with aluminum heads. Careful with the spring pressure on those dual springs. Mine had them also and I had to change them because the open pressure was WAY too high for the cam. If you're using a flat tappet motor you'll wipe a lobe if the pressure is too high. The TFS springs that came on the heads were at 420ish pounds and I changed to a single spring at about 300 pounds open pressure.
Even if you have to change the springs I'd say you got a good deal. I don't know the MSRP of those heads but that about $800 less than I spent on mine. It cost $75 for an engine shop to change the springs. I bought the tools to do it myself, but couldn't get the heavy ones compressed enough to get them off.
E
EricLar80
Thanks - I'll be sure to measure the spring force, it really didn't cross my mind. I did take both and intake and exhaust valve off last night and the springs didn't seem really heavy, but it did feel like more than stock springs from what I could tell. I have the roller block, so I will be going with roller lifters, but there is probably no reason to have overly heavy springs either.
Thanks again.
Eric
broncnaz
Just for info I have TFS heads 2.02/1.60 valves on my 302 and it does great. With a stroker you definetly wont have any issues. but I'll second the statement about the valve springs the wrong springs can cause a lot of issues even with a roller cam.
HoosierDaddy
Eric
Your hydro-roller cams can have much faster ramp rates than flat tappet cams , that is part of the reason for the roller portion , the roller will "roll" up the ramp as opposed to a flat tappet "sliding". The flat tappet could bind or something on a steep ramp and wreak havoc.
With the valve train accelerating that fast , you need higher spring rates to keep it in check , keep the valves from floating , keep the lifter in contact with the cam etc.
This applies to mild cams as well as race cams.
E
EricLar80
Right. It's just that for my (our) application, there is no reason for overly heavy springs as the profile will probably be pretty tame compared to some stroker motors. But, I do appreciate the input.
Makes me think about cam choices - does anyone have any suggestions? I will be running EFI with the 393w, and it needs to be fully streetable. Ryan had posted this on FSB.com a while back regarding cams and EFI:
Best 5.0L/5.8L (302/351) Roller EFI cam:
89-95 Mustang 5.0L HO
Ford Part numbers: E8ZE-6250-CA / F1ZE-6250-AA / F4ZE-6250-DA
* Advertised Duration: 276 / 266
* Duration at .050 in.: 214 / 210
* Gross valve lift: 0.444 / 0.444
* Lobe separation: 115°
I know the long stroke will make the cam feel smaller, so given that, should I get something a little more than he suggested for 351w (stock mustang cam). I currently run the crane cam 444211 on my 5.0 and I like it quite a bit. Plenty of low end, but it does die out around 4500 rpm. I would be good with getting a little more operating range up top given the extra torque that should be available in the low rpm range.
What cams are people running with their stroked 351w's?
Thanks,
Eric
HoosierDaddy
Either way , I would use the springs rates the cam company suggests , even for the mild XE258 I was looking at , comp cams called for duals.
Just sayin .... don't pitch those duals yet!
Camquest suggests for a hi-torque application in a 4500 lb vehicle:
35-308-8
35-349-8
35-320-8 (1.7 rockers)
among others ....
