I’m looking at running the 94’ explorer radiator and have some questions on the install.
Im running a 98’ explorer motor with the broncoguy a/c compressor. 2.5“ lift with 1” body lift, 4r70w trans with aux cooler.
Broncos a family cruiser that will see light off-road use mostly street.
For the guys that have installed this radiator. Is anybody making lower rad brackets? or just getting them off the Ford Taurus and welding them to the core support. Does anyone pictures of the lower brackets they have made so I can get an idea of what I’m lookin at as far as fab goes. Also for the upper mounts, will the tabs on the 94 rad just fasten to the core support and doing away with the stock upper brackets.
This swap seem affordable being that the radiators are cheap and have the trans cooler on the right side, good warranty, and readily available. It’s hard to spend money on the (Ron Davis) when guys are having good luck with the explorer 4.0 setup. I’m not thrilled about cutting my stock lower rad mounts off but if that’s what needs to be done then so be it. Any pictures of this swap will help
