Another 4R70W question: linkage
kholding
kholding
Las Vegas, NV
Mattt, I looked at doing the same as you but I think mine is a little tighter with the high pinion axle possibly? It put it too close to the driveline again. I'm worried about the winters shifter arm as well, it's right above the driveline, even closer on mine! I think I might have found an option, just have to make a bracket (didn't have enough on this one to drill the second hole after I moved it again). Thinking about drilling a hole in my crossmember to run the shifter line through to make sure and keep it off the driveline. The hole would go through the vertical section to keep the line straight and out of the way.
Amac70
ME
heres a thought since you are all open right now (no body) i would call winters up and ask them how to reverse the cable routing i believe you can make it function the same and go the other way. then you could come from the front. I was in a hurry when i did mine so didn't look really hard at doing that. that would solve most of the problems. But yeah mine is still very tight even with the smaller dia drive shaft. You can see where the bolt touched several times. That was during high speed sand stuff. In moab this year nothing touched on the slow speed flexy stuff. I am also running hp 44 in front. just not alot room there.
kholding
kholding
Las Vegas, NV
Not a bad idea. I looked at trying to reverse it but wasn't sure if that was an option. I'll go out and look at it again. Needed a little break.
mattt
About 2 years ago I called Winters and asked that exact question. At the time & with who I spoke to, the answer was "no way to reverse the cable." I wish it could happen....it would be an improvement on many fronts in my opinion.
My bracket and cable @ the bracket mount are very close to the front shaft CV. I don't think it's a problem at that point...the CV doesn't move very much at all during flex. The best way to see how close the driveshaft will get to the cable, shift arm, etc is to cycle the suspension with everything in place, including bumps stops. Best is to pull the springs and cycle. If not, you can cheat and do it with a forklift like I did...that gets you close but I couldn't get it to full stuff with the forklift....if I would've kept going the Bronco would've flopped over on it's side. I can see how a HP44 would put the driveshaft closer to the shift arm & cable end.....at the other end(CV end of shaft) though, the HP44 should have no effect. It's all in how the crossmember, transfer case mounts, etc are positioned. I've seen variation there between different Broncos.
kholding
kholding
Las Vegas, NV
I'm hoping the set-up in my last pictures works. Seems like the best option so far. Just need to make sure I get the distance for the bracket just right. Doesn't seem like there is very much adjustment at the end of the cable to get the gears to line up with the gate? Seems like I am always 1/4" off at one end or the other (goes into park good but is 1/4" short into 1st)??? Can't seem to get a good solid lock into all of the gears...
mattt
There isn't much at the trans end of the cable. There is more if you disassemble the shifter housing....at the other end of the cable. You can play with both ends of the cable to get it adjusted.
I'll be interested to see if you get perfect alignment between trans and gate plate. I spent too many hours on mine trying to get it right and no matter what combo I tried of adjustments at both ends of the cable, it was always like you describe, a little better, or a little worse. Good adjustment up near park makes for not so good at the "1" position and vice versa. I finally settled and left it where Park is not lined up perfect but every other gear is. For Park to be perfect, it would have to go forward another 1/8-1/4". I suspect the gate plate is not exactly right and that it's mfg'd that way.
mattt
Another thing to keep in mind is that your front driveshaft doesn't necessarily move straight up and down during articulation. It will shift side to side depending on the situation.
Amac70
ME
also on the shifting i wouldn't worry to much about it till you get your optishit hooked up its going to tell you weather you are in gear or not.
kholding
kholding
Las Vegas, NV
Cut a new bracket today. Made sure to set the cable bracket length to the exact distance the original bracket would have been. This really helped clear up the shifting issues. After that, I just used the barrel adjuster of the shift arm to make fine adjustments (cable is obviously not hooked up in pictures). Also got my JB Fab twin sticks today!
