- Joined
- Aug 23, 2007
- Messages
- 24,451
Keep in mind that more torque will result in more future drivetrain breakage. In other words, the spending doesn't end when the stroker is installed.
so what is so special about the coyote engine? whats it going to do that another engine wont?
Dont know how you figure the coyote engine cost the same as a built 302 or 351 guess the only way it would is if your are looking for the same HP numbers. I still like the simpler engines all these new ones with cam phasers and varible cam timing may be nice to have when they are new but as time goes on parts wear out and problems arise and they wont be cheap problems to fix.
To me for the most part the coyote and other small displacement engines are fine for cars where you can cruise around then open them up but for a 4wd they dont impress me as a engine to have as most of there power is made way up there in the RPM's.
so just a quick google search and the coyote can be had for a little over 6k
I
The biggest pull to the Coyote is the potential for significant fuel efficiency gains. It doesnt surpise me that a properly geared 351W is more efficient on the highway than a 5.0...the 5.0 may not be in the ideal torque band to push the big box thats jacked up and on 35" tires. I think I would get better efficiency with a comparable 351W...keeping everything else the same. For whatever that is worth. Do I have plans to change it anytime soon? No.
John
Gas mileage potential draw? Well you might get slightly better mileage than a 351 and have more power once your in the RPM's. but in a mustang they get around 25mpg.(only slightly better than say a 1992 mustang 5.0 which is a common swap and we all know nobodys getting close to that in there bronco) In the F150 which is a detuned coyote engine and probably better suited for mileage they only get around 20 mpg. Throw that engine in a bronco and your probably back down to the mid teens maybe high teens if your lucky. really not much better than what a well tuned old V8 will get.
Im probably a little to set in my thought process of course its kinda more geared to my wheeling kinda dual purpose street and trail nothing to extreme. but can get there and back with little worry about something going wrong and having to find parts. I like things simple and well old school.
On the other hand at least its a Ford swap so that gets some points.;D
You can look at my sig for my configuration. I am probably heavier than many due tothe galvanizing, full Line-X treatment and extensive cage and storage...guessing at or a little over 5K lbs. The reality is that I see 12 consistently driving aggressively or putting around town. On the highway, I can get 14, maybe. On the interstate, despite the good gearing and the overdrive, I am not quite in the optimum powerband at 70-75...so I have to put a little more skinny to move it ont he hills. At 80, its a beast and will climb, dance and sing, but its also drinking gas like gatorade and I can see mileage closer to what I get around town than what you might expect for highway driving. Its aerodynamics. A bit more torque and it would probably pull a little better at 2200 rpms, hence why I recommended the 351W. The torque profiles that I have seen from the Coyote and new ecoboost engines is available much lower in the rpm range, so you can get away with keeping your gearing up and having the power at those lower rpm ranges. This is where they are more efficient then our 302/5.0 and 351 counterparts of yesteryear. I like my 5.0, dont get me wrong, but if I could do an engine swap and have the same torque and power just off idle and full-on by 1600 rpms, that would be awesome.
As far as only upper teens, compared to my 12 mpg, thats a 50% increase in efficiency.... At $4/gallon, thats a huge savings for a driver. Hell, I would love a 20% increase. 15 mpg in town and 18-19 on the highway would pay for itself in a couple of years, if you drive it. Doubling your fuel economy, that would be incredible. I think those sorts of powerplants will come eventually. Another aspect to our Broncos, is the axles themselves. I have read and was told by a tranny specialist that the 8.8 is much more efficient than a 9". There are several ways we can improve these trucks is my point. Old school is great...I have one, I built one, I love one, but at some point, if you are going to rebuild or upgrade and you can use something with comparable or improved strength, power or efficiency, then why wouldnt you move on to the newer tech. That may be the only way to realistically keep these rides on the road--and use them--or at least afford to use them.
Just shit to think about...
