BroncoBub Build
BroncoBub
BroncoBub
Completed painting the D44 axle housing. The pictures tend to make the center section more of a green tint but in reality it's gray cast iron look.
On a side note: Wife not happy finished parts or in our spare bedroom;D;D;D
BroncoBub
BroncoBub
Test fitted the tailgate today. Went on without a hitch. Now I have to take it apart and prepare it for primer.
sprdv1
REBEL
great progress... take a few hours for that paint/primer prep
U got this
BroncoBub
BroncoBub
Centech Wire Harness / Vintage Air
Picked up a new Centech wire harness and a new Vintage Air a/c for the Bronco from someone on a facebook market place Bronco site. He was selling a ton of new parts for a build he started a couple years ago and since decided to sell the lot. I got both for an unbelievable price. He also sent them fedex next day at his cost.
Bub
PS : I believe he sold the rest of the lot today. I missed out on some other great parts.
chuckyb
Nice work, Bub! The Centechs seem difficult to find right now so great score!
BroncoBub
BroncoBub
Hey Thanks, yes just came across someone who started a restoration and decided he couldn't finish it and started selling off new parts to recoup some money.
Bub
BroncoBub
BroncoBub
Dana 20 Tear down
Since I really can't open the garage door because of the cold outside, I decided to tear down the transfer case and restore it. I'm waiting on a rebuild kit and should be here Friday. I wire wheeled the case until it showed a cast iron finish than I wiped it down with cleaner. Not totally complete at this point but, I thought I would show the progress and the paint I chose to spray it. I'll also spray the same brand engine primer before I totally complete it. In the picture with the black pointer; above the line is bare cast iron that I wire wheeled and below is the paint color I shot a little test area of. Pretty close to a perfect match. Just thought i'd share.
Bub
BroncoBub
BroncoBub
Finished up with the transfer case and the intermediate housing plus did the yokes. Next up rebuilding of the transfer case.
Bub
BroncoBub
BroncoBub
Preparing for primer on the frame. Checking to make sure leaf spring and all attaching points line up before they go to primer also. In the second picture, is that the correct way to mount the rear spring to the frame? She always helps me...
Bub
BroncoBub
BroncoBub
that's the important part brother.. whatever you can do when you have the time and it'll happen eventually...
It's starting to get exciting watching all the parts and pieces come together.
;D
BroncoBub
BroncoBub
Frame Painted
Frame primed and painted Hot rod black. On to the next chapter...
Bub
BroncoBub
BroncoBub
Leaf Spring Refresh
I purchased the WH stock rear leaf spring from a forum member here and decided since I have been restoring anything that was painted, I figured I would clean up the leaf springs. I like to visualize what they looked like in there raw state before painted. Call me anal....
Bub
subjb1
I like it. Did you clear coat it after stripping it down
BroncoBub
BroncoBub
After I wire wheeled it down to metal I treated and painted it with cast coat gray paint. Perfect match to the actual color of the leafs.
