Building a 393 low end torque engine
jckkys
My 351 is getting a new top end and cam. If it turns out to need re-bore, pistons, etc., this may be a good time to do a 3.85" stroke crank. My goal is building a great TRUCK engine. This is an entirely different concept than building a race, performance, or hot rod engine. Trucks need a flexible broad power band, not high RPM power. Has anyone attempted to build a 3.85" stroke 351 that pulls from 1500-4500 RPM? The original 289-302s in my 3 EBs, made all the HP needed for off road exploring and the 65 MPH highway drive to get there. The deficiency in these engines is low RPM torque. A 351W swap was a huge improvement, so 393 CI should go further in the same direction. I use a stock C4/torque converter, 350 gears, and 31" tires. Competition Cams recommended a 198/206 degree duration hydraulic roller cam with 4 degree advance. Is this too much or too little cam? What compression ratio?
I will run a carburetor and maintain a stock engine compartment appearance, so cast iron exhaust manifolds and Ford carb. Are there any specific recommendations?
Doesn't sound like too much cam to me. Especially with the considerably larger displacement. Obviously there's more to cam choice than just duration, but that seems like a good range at least initially.
The 4 degree advance should be a notable difference as well, in how it gets up and goes.
I'll have to check mine to see what the duration is again. It's a cam (non-roller) that several others on the NorCalBroncos forum chose to run, with excellent results. Works with a carb, but very EFI friendly with the 114° centerline.
I believe most were in stock displacement engines though, so will check that to see if anyone is using it in a stroker.
pcf_mark
Are you using the stock 351 heads? If so I port the exhaust they are notoriously poor flow at all rpm. Also you aid stock exhaust manifolds - properly sized long tube headers make more torque than any manifold. You may leave 20-40 ft-lbs on the table with manifolds.
That cam is really short duration for an engine that big. What is the lift? If the lift is .450-.480 it is really throwing the valves open fast and dropping them closed so it should have great throttle response. But if the lift is less it is going to make power down low then drop off like a rock.
As a reference point the stock 5.0 cam is 210 duration and .444 lift for an engine only 70% the size of yours.
A stock 351 cam is 206/221 and .445/.453 lift.
Looking at these two it makes me think the cam is too small. You may get great off idle performance but when you floor it there may be nothing left. Like if you go to pass someone it may already be out of air.
I would have guess .210/.225 and .480 lift. The cubes plus the stroke really pull the intake charge in so you do not need a lot of cam but the exhaust ports are awful. Smaller than stock is not usually what you need for an engine that is almost 50 cubes bigger.
Timmy390
Conway, AR
I personally would change the 3.50 gears to 4.11's and feel like I gained 100fpt but that's just me.
X2 on the heads. What heads are you using? Make sure your springs can handle the cam lift.....
While I know your staying carb, here is the cam I run with my stock roller block 351w (20 over) with GT40P heads (upgraded springs) and EFI setup. I pulls......
Comp 35-349-8/XE264HR
Advertised Duration (Int/Exh): 264/270
Duration @ .050 (Int/Exh): 212/218
Gross Valve Lift (Int/Exh): .512/.512
LSA/ICL:114/110
RPM Range: 1,500-5,500
Tim
68ford
Maybe consider 112 lobe sep on your cam choice. Peak torque will be at a lower rpm and make broader torque.
pcf_mark
When you reduce the LSA you get more torque but at cost of idle quality and vacuum. With a carb this can be a killer it can cost you 3-4" of vacuum.
Montoya
But with fuel injection and a tuner, this makes for one mean sounding lump! :cool:
Your points are completely correct and if you run vacuum brakes you will have no help at idle.
68ford
Just saying the guy wants torque and at lower rpm. Tighter Las makes more torque and also at a lower rpm. I don't think 112 will be bad at all for him since he is looking at low duration cams. I run a 108 lobe sep with 270 duration and yes, idle.is terrible. But I think he would be fine, actually better.
J
jckkys
STOCK 351W heads can be many things. After 1976 they were simply 302 heads. Until then they were pretty good as TRUCK heads for an engine that size. What's good for racing is no good for a truck head. Mine are GT40 heads from a 1996 Explorer. They have the ports smoothed and valve shrouding removed. You need to specific. Too much thought and marketing is focused on high RPM. I have no interest in power at 5000 RPM or more. A smooth idle at 500 RPM is worth more, so is a stock looking engine. Headers are a headache. They're noisy, leaky, and cook the engine compartment. They don't improve low RPM (1500-3000) torque.
J
jckkys
The cam is Part#35-000-BRF
valve lift is intake .435 exhaust .480
duration is " 251 " 262
I'm going with a 480 CFM 4100. The exhaust after the cast manifolds will be 2 into 1 with about 2" diameter and the quietest muffler I can find. What works for this? The intake is a Performer EGR with the EGR port blocked off. It's the only aluminum 4bbl 351W intake that has no hood clearance issues. The original smogged down 302 had sufficient power, but not the torque needed from 1000-2500 RPM. In fact my 1968 289 had better torque over the whole power curve.
The compression ratio is an open question. Where a big cam can tolerate more compression, this advanced short duration cam may need somewhat less. Any recommendations? The rocker arm choice is another question. Stock appearance dictates stock valve covers. I know Comp Cams magnum roller tips will fit but now there are stainless full rollers that may be from China, and may fit under stock valve covers. Which way should I go? Also 1.7 ratio arms are available. Are there any suggestions?
PNW
So many variables here...
I'll start and not have enough keyboard to get into a lot of detail.
Offenhauser dual port intake fits and would be a good choice for high port velocity for low rpm response/use
https://www.summitracing.com/parts/ofy-5883/overview/make/ford I know guys that have stuck them under Bronco hoods.
A 450 CFM carb will be marginal...if you want low end torque you need to have port velocity and the way to do this is with small venturis on your 4 bbl. A Q-jet would have much better throttle response with the tiny primaries than some typical square bore...you will really notice the difference...air speed from the air filter to the combustion chamber is the key...not necessarily volume . Don't think a qjet won't work...they are stock on 6cyl to 500 Caddy's and we currently run them on 190 HP 4 cyl marine engines...excellent carb.
Cam...any cam that is a good choice for a 351W is not what you want... you have a TON more cubes and just as important is the stroke...stroke length (and of course other factors) plays a big part of cam choice.
Compression ratio...have you figured out what rods and pistons you're using? The typical 393 doesn't give you many choices for compression ratios... some try to lower the CR with a thick head gasket which creates all sorts of other issues with quench numbers that are not desireble...
Your engine and desires...
Lot's to figure out...don't pick that cam till you figure out what rods/pistons/heads (steel or alum)/gaskets you CAN use, not necessarily what you want. My .02 on that cam is it's way to small.
68ford
If torque below 5000rpm is the only thing your concerned with, I'm curious as to why only going with a 3.85 crank? You can fit a 4.100 in a stock block with a little clearancing I've been told. Cast crank would be fine for your application so it would not be much more I would think. Assuming your .030 over that would put you at 418ci.the longer stroke increases port velocity and the low end torque would be a lot more. My 438 with 4.100 crank, 220 afr heads and 290 duration, .640lift cam on a 110 lobe sep hit 500 lb tq below 3000rpm. 2000rpm it has over 450tq.
pcf_mark
Just my experience / opinion and you did ask sooo...
You are looking at putting a properly tuned intake manifold and cam in your engine but willing to throw away all of that by not using headers? They are tuned length for a reason - they are the opposite side of your engine air pump and need to be sized just like the intake. Headers build torque at all rpm not sure where you heard headers don't make low end torque that is incorrect. Buy good ones with the ball/socket collector they don't leak and get them coated much better than old school.
You have a big engine and a tiny cam, not even big enough for 351 which does not equal low end torque - it equals peaky engine performance. Good in a very narrow range but difficult to tune and power falls off sharply on both sides of the peak. As 68Ford pointed out - a big engine needs a sized cam for the engine and stroke. A stroker really pulls the intake charge hard.
PNW
I agree PCF mark...no way would I ever plug off the end of a pipe to choke the flow of pipe...then probably wonder why the pipe doesn't flow enough- or never know that it could flow so much more.
Headers are not leaky...buy good headers, excellent gasket, Grade 8 fasteners...torque them down ONCE and drive off and forget they are even there...seriously... Stage 8 fasteners will keep your bolts from backing out...period! NO retightening ever needed. I never touched ONE header bolt for 14 years with Earl's dead soft gasket and Stage 8 fasteners... they very seldom brake unlike stock cast iron manifolds... I put on at least a thousand miles/month...minimum.
Are you going with a 3.85" stroke crank to save money (perfectly ok of course) but like I mentioned earlier- this crank really limits piston selection and you typically have VERY high (by today's standards) compression ratios with this crank...slap on stock, low flow cast iron heads and heat and detonation is a real issue...
Give us some feedback... we're just tossing stuff out here because most of us have built strokers and can help with some good feed back if wanted.
Good luck on your build
68ford
Also, my cam previously mentioned, that appears large on paper and maybe it would spin high rpm in a 351w, but in my 438 it peaked 560HP at 5600 rpm. Of course you would not like the idle, but even though then idle is choppy, as soon as you touch the throttle it make huge torque. It's not like throwing a big cam in a short stroke 289 25 yes ago
J
jckkys
The conversation seems to be reverting HP. I realy don't care about HP. As said the smogged 302 had all the HP I needed, and that was only about 133. The problem was a lack of low end torque. By low end, I mean less than 2000. I drive on what the Forrest Svc. now calls OHV trails. They used to be called jeep trails. Now Jeeps are much wider to appease corporate lawyers fearing rollovers. EBs fit through these narrow trails. I see no use for more than 300 HP. A 300 in line 6 would ideal, if it fit an EB. They develop peak torque at 1600 RPM and peak HP at 3800. The stock torque converter has a stall speed at 1600. That's where I need torque. The C4 shifts at 4500. What an engine does at 5000 is irrelevant to me. It will never see 5000. I've been running a Ford 351 Lightning cam with the OE 302 exhaust system. The Lightning cam is very close to the Comp. Cams product and the Explorer F4TE roller. This cam pulls well to 4500 RPM, or all I can use. The recommended 4 degree advance, Comp Cams claims will help at less than 2500.
There is no way I'd use a Chevy carb. They look too far from OE. Stock fuel lines and linkage are also no good. I also have a square bore intake that's the only 4bbl aluminum that fits under the hood. The 480 CFM 4100 has plenty small primary venturis at 1.08" and unlike quadrajets they have annular discharge boosters.
The 3.85" crank uses 302 pistons offering more not less choice and less expense. That's the reason for the 3.85" stroke. As stated the heads are GT40s not stock. The stock 1987 E7TE heads have worked well for over 10 yrs. The much larger exhaust valves and ports on the GT40s may help, or not. I'll find out. The stock 302 pipe is only 1 3/4" so 2" is a significant increase. The 1000-4000 RPM power band with smooth idle at 500 is my goal.
All headers are noisy even the shorties. Also they greatly increase under hood temperatures. Not desirable when it's 110 outside. Ads for headers never talk about what they do at less than 3000 RPM. I think the reason is that they don't help until the engine revs higher.
vintage bronco
As being a svt lightning owner I can tell you it was way under cammed from the factory even for TQ I would for sure do a custom roller Cam I do them in everything I own I have a 5.0 liter I am putting together as a T/Q build for me 83 F100 Daily driver Factory manifolds are going to kill it if you buy Quality headers & good Gaskets NO ISSUES. You can have more than enough low rpm T/Q, Fuel Economy, but Requires a super good Combo, Roller cam is the Key, And do not fear the Exhaust system 2.5 into 3"" Single and at least 600 cfm carb Summit Brand 600 is a remake of Autolite 4100 with Holley tuning Parts.
Timmy390
Conway, AR
I'll just be "That Guy" (see is anyone gets the joke) and say.....why not go 351w? You get the longer stroke and the cam selection is better IMO. Mine really pulls with the stock 3 speed and 4.11 gears.
I think you can build a torque monster 351w cheaper than a stroked 302 and your not burning the candle at both ends like with a stroker.
Tim
