Chirping Brakes!
Bronco Paul
Does anyone know if a rear drum brake chirping can be cause by anything other than an out of round drum? I have new outer bearings, cylinders, drums, & hardware. I removed the drum and noticed that the top of the forward facing shoe has wear with the brake cylinder fully closed so all I can figure is that I got a cheap Chinese drum that is now out of round after about 5K wear. I also have a slight resistance just before coming to a complete stop. Anyone have this problem?
Thanks,
Paul.
Jdgephar
I've had cheap shoes there the glued on pads came off and locked up the rear wheel when you hit the brakes
Check the pads on the backing plate. The shoes wear a ledge on the pads and can cause these issues. Sometimes you can grind them smooth again and if real bad mig weld them up and resurface them. Supposed to put a smear of white grease on them but most people dont.
Pa PITT
Stephenville TEXAS
I don't think your problem will be in the drum.. Now I've seen a few set of rear brake shoes twisted but the get past the re builder and shipped out. I'd think you have a bad mounting setup. or a twisted shoe . Or some other item not on straight.
.. But I bet it's not a drum.
Bronco Paul
Bronco Paul
Last night I took off the drums and swapped sides and now the noise is on the drivers side, so I'm pretty sure now it's the drum. A good drum will run about $140...probably look to replace both while I'm at it...might be a good excuse to upgrade to rear discs!
Sent from my LG-MS770 using Tapatalk
Pa PITT
Stephenville TEXAS
I think $140.00 is way high for a drum.. I'd be thinking about 40.Bucks ..
..And I bet I get hammered on this but rear disk are over rated for their expense.
.. Good thought on swapping sides with the drums. But what warped it I don't think it's just because it was a cheap one.. In today's world there are probably more cheap one installed than High Dollar ones .
