jdeignan
- May 24, 2015
- 205
Hi, if you squirt tranny fluid in the cylinder
Good luck
Ok so this worked.. except now that cylinder is putting out 180psi.. just leave it be?
Thanks for the help
Good luck
I've seen some modern cars trail a stream behind them I would not chase that as a symptom of anything.
When I my stock engine was carbureted i was pulling 19" steady in neutral. I had 16 degrees of timing but that made the exhaust smell nasty backing it down to 12-14 is better.
This is with the vacuum advance disconnected? And where are you taking the vacuum reading from again?
And did you mention what type of distributor?
Last thing i would do then would be to attach your gauge to a known-good stock engine of any type. l
I warmed it up, loosened up the dist and tried to see what I could do to the vac reading with timing.
Results: If I move in either direction, vac drops to about 10 and the truck wants to die. Think I may just be stuck with 15.
Are you saying when you advance it the idle does not go up? In the other direction it will retard so that would slow the idle down reducing vacuum.
You may also be chasing a non problem
Do me one last test
If it bounces between 13 and 14 consistently I would call that cam. The plugs look pretty good to me. Just check the runner for that really light one. Is there a vacuum device connected to it anywhere? A vacuum tree or port? Power brakes connection? It looks a little white so maybe it is running lean. If it is lean it could be a vacuum leak.
