couple EFI issues please...
blazinchuck
alright...i just swapped in my 5.0 from FBG to the 77. it cranks up and runs good for a miute...then starts to surge and almost shut off. ive checked the codes and its the usual ones(81,82,85,84) also...ive notice the alternator wire from the rjm harness doesnt have any 12V...so its not turning my 2G alternator on. the alt was working fine on the 306 motor I took out of the 77. I have the alt hooked up right...but its not getting turned on...maybe thats my whole issue...not sure.
please help, im in the garage now w/laptop to check replies...and im starting to untape the centech harness where the rjm ties into it...to double check connections
Viperwolf1
electron whisperer
Alternator wire gets power from the MA/O2 relay. Good place to start looking.
Viperwolf1
electron whisperer
Ohm the alt wire back to pin 87 of one of the relays. It's a good idea to pull the fuses first. If that wire isn't getting power the the MA sensor and O2 sensors probably aren't either. Diagram is here: http://fordfuelinjection.com/?p=6
blazinchuck
blazinchuck
i cant find list showing what each of the 4 fuses go to...nor what each of the 4 relays go to for the rjm harness
blazinchuck
blazinchuck
i dont have continuity between the alt wire and 87...is that what you wanted me to check?
Viperwolf1
electron whisperer
You need to look at the diagram near the bottom of the page I linked. Ryan doesn't label the relays or fuses.
Might check the MA sensor plug for continuity to relay. Look at the diagram that shows the MA connector to get the right pin.
blazinchuck
blazinchuck
ok...now the pumps come and dont shut back off when putting the key in run wtf? 1st they didnt even come on...i pulled the fused, checked it and reinstalled it...then they started pumping nonstop
blazinchuck
blazinchuck
aight Phil...i guess ill try those 1st thing tomorrow... its 12:30 now...im pissed and hitting the sack. thanks for your help,Chuck
marty
massapequa, n.y.
well i don't mean to keep bringing up my issue but i had the no voltage to the MAF/o2 sensor/alternator excite lead and and i chased my tail for months due to the fact i had no volt gauge hooked up and it would show a code for only low voltage to the maf. everyone here pretty much kept telling me i had a vacuum leak by the way it was running. after numerous tests looking for a leak i noticed something was wrong when winter came in and i used the blower motor and heard it pickup in speed when the truck ran good. knew it was electrical at that point so i put a voltmeter on the alternator and saw 12 volts when it was running and not charging checked and started to wiggle the harness around and tapped the relays and sure enough found a bad intermittent relay cutting in and out. the rjm harness uses tyco relays made in china so i replaced them with some NOS bosch relays which i come to find out the robert bosch company sold the relay end of their business to the tyco company which is a china based company. i hate chinese made junk parts especially electrical parts. maybe swap out some relays with known good relays and see if you still have your problem.
blazinchuck
blazinchuck
yeah...the best i can tell, things started working when i swapped relays around. got it running this past saturday...however, went to take it for a drive yesterday and it wont take any throttle now! start giving it gas and it will bout shut off...idles fine and will slowly rev up...but if you stab the throttle...it just wont take it. so not sure where to look now:cry:
blazinchuck
blazinchuck
Pull codes..
ill see what i get, when i get off work. havent checked any codes while running yet. right now the check engine light isnt on(i wired one in where the brake light would be)
whats the correct way to check KOER? start truck then ground seft test-in?
thanks,Chuck
blazinchuck
blazinchuck
ok...KOER(12,21,94,44,33) KOEO(81,82,85,84)
l swapped out the MAF and fuel pump relays with new replays. i can slowly bring engine up in rpms...but can not stab the throttle
Viperwolf1
electron whisperer
Maybe vac leak, IAB not working, MAF sending out incorrect info. Look for leak, clean MAF and IAB.
