DanWheeler
After about 8 months with the NP435/D20 combo I'm already sick of it.
It's time for a 4R70W 4 speed automatic w/ overdrive transmission and Atlas II transfer case.
I picked up the 4R70W today from a guy in Vancouver, WA for $150. The donor Explorer was a 2001 with 110,000 miles on it that rolled in a recent snow storm. He had 2 5.0 explorers that had rolled. The transmission appears to be in perfect shape. At this point because of the expense of the swap, the atlas and all necessary parts and the very few miles I drive per year I plan on installing it as-is. I may rebuild it later if necessary.
I'm going to try to keep this thread up to date with parts, prices, what works, what doesn't work, etc.
Parts:
- 4R70W Transmission from a 5.0 Ford Explorer - $150
Some output shaft info on my 4R70W:
- 1" of spline protruding past the flange (flange = end of the transmission)
- 3/8" of taper past the 1" spline (total of 1-3/8" sticking out past the flange)
- 1-3/4" of spline inside the flange
- The shaft behind the spline is smaller in diameter than the splined area
- 3/4" multi-clock spacer - $60
- Baummanator electronic transmission controller - $400
- Baummanator full harness - $150
- Atlas II Transfer Case w/ short tailhousing (saves ~2" in length)- about $2200
- portable GPS unit since the short Atlas tailhousing won't accept a speedo cable - $100
- Transmission temperature gauge
- Derale Atomic-Cool plate transmission cooler kit - Derale 13950 - $180
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DER%2D13950&N=700+115&autoview=sku
The Derale Hyper-Cool is one step up from the Atomic-Cool and is 1" thicker than the Atomic-Cool. The Derale guys siad the Atomic-Cool should be sufficient for heavy offroading so I will go with that since it is cheaper. The kit (Derale 13950) comes with some hose and fittings and an inline thermostat.
- 3G alternator upgrade so I can run the Derale transmission cooler fan - Ebay from Romeo Electric - $190
- Transmission backing plate / separator - $70
http://store.summitracing.com/partdetail.asp?part=PMA%2DPA26445&autoview=sku
- 164 tooth / 28oz flex plate - $63
http://store.summitracing.com/partdetail.asp?part=FMS%2DM%2D6375%2DG302&view=1&N=700
Hedman Hedders shorty headers - $150
http://store.summitracing.com/partdetail.asp?part=HED-88400
These have been confirmed to fit an early Bronco
2.5" to 2.5" reducer flange for Hedman headers. The hedman headers say they are 2.5" collector and thats true but the reducer flange they come with goes down to 2". This kit is a 2.5" flange for 2.5" exhaust.
http://www.summitracing.com/parts/HED-21123/
- New exhaust TBD - either make my own or take it to Muffler King in Kirkland
- New Explorere 5.0 starter - $49 from 14Rebuilders on ebay
- Torque Converter (Will use the stock one from the Explorer)
- Throttle position sensor (more info on this later)
- Floor shifter (going to try to re-use a Hurst shifter I had lying around or a new Lokar)
- New driveshafts (TBD)
Write-up on Pirate 4x4 about cutting down driveshafts
I may be able to chop my almost new Wild Horses extreme driveshaft and put it in the front or pick up some driveshafts from a 90's explorer. If they don't work or vibrate I'm only out $60. I may also purchase a new rear shaft from Wild Horses since my truck sees plenty of highway speeds and then chop a junkyard shaft for the front. I can't remember the last time I went over 20MPH in 4wd.
Notes: (will be updating these as I go and cleaning up when I'm done)
- ZF crossmember from BC Broncos will probably not work for 4R70W (Confirmed by Stretch) it's close but not close enough to be worth it.
- AOD crossmember from Tom's will NOT work for 4R70W (Confirmed by Tom's)
- 4R70W length w/ 4x4 tailshaft housing - 27"
- Mounting holes on stock Bronco crossmember are 22" from front of bellhousing.
- Mounting holes for 4R70W are 23" from front of bellhousing.
- No adapter necessary to attach an Atlas II transfer case to a 4R70W
- A spacer may be necessary between the 4R70W and the Atlas II (there are 3 available from Advance Adapters)
- The 3/4" spacer allows for several clocking options
- 4R70W cooler lines are 3/8" steel tube
- Top line is the return line for cool fluid coming from the cooler
- Bottom line is the send line for hot fluid going to the cooler
I'll be editing and adding information as I go but for now here are some pictures.
4R70W from bellhousing to tailshaft housing is exactly 27"
27" puts the end of the 4R70W right about in the middle of my Dana 20
The Atlas II with short tailhousing is about 12" so I think I'll be adding 5-6" to my drivetrain. More accurate numbers when I get the Atlas.
Parts:
![526877190_2vGfn-L.jpg](http://dano.smugmug.com/photos/526877190_2vGfn-L.jpg)
![526877198_PyQHh-L.jpg](http://dano.smugmug.com/photos/526877198_PyQHh-L.jpg)
![526877188_Ftm6n-L.jpg](http://dano.smugmug.com/photos/526877188_Ftm6n-L.jpg)
![526876998_iDnLw-L.jpg](http://dano.smugmug.com/photos/526876998_iDnLw-L.jpg)
![526877303_kA3pL-L.jpg](http://dano.smugmug.com/photos/526877303_kA3pL-L.jpg)
