All wrapped up with the mechanical work and a little bit of back and forth in the garage, just need to get it out for a test drive.
Pedal feel is good and I'm able to lock the rears up on the slick garage floor in 4-low which I had trouble doing before.
All the front lines are redone running down the panhard. It came out pretty well. I had a leak on one of the hard lines I made that I think is fixed but keeping an eye on it.
The diff cover is off because since I was pulling the ARB blue line I thought it would be a good time to replace the little rubber compression o-ring where it transitions from copper tube into the brass fitting but I was wrong. The copper tube slipped down inside the diff and that was that %)
