Ok, so the only things that are not hooked up: clutch switch, brake switch, vss. Everything else is hooked up, I ran a hot to the 12v hot in on the dash harness and turned over the motor. I have spark! the only problem I have is the fuel pump not kicking on, I primed the fuel system before I cranked it over, I have the plugs out now and I could smell gas so I have reason to believe the injectors are firing and everything else is working. The only thing I am not certain on is the fuel pump. Tomorrow if I get done with work soon enough I'll come home and wire the computer in for good through the ignition, toss in some plugs and water and see what happens.
Here is a crappy engine bay cell pic and a few pics of the throttle bracket I had to make. for the 36 inch lokar cable for the throttle. I know 36 is a bit long but I wanted a zero bind setup.
