Crawdad
- Feb 16, 2011
- 3,635
I hung my cooler down almost touching the ground. I filled it up cooler first, then attached the hoses, then slowly filled hoses. Then attached hoses to PS box, then slowly filled it up. Next I attached hoses and filled them up with fluid. Attached hoses to Sagi pump. And slowly filled it up with fluid. At that point I would turn the wheels from lock to lock with engine off and wheels in the air (use extreme caution). I must have done that for a couple of days. Then I would start the engine for like 10 seconds and turn wheels from side to side with wheels in air again. I did that off and on for about a week. All the while I was checking the fluids in the Sagi. I may have went way overboard but I didn't have any vomiting or air bubbles. Eventually I let the front end down and turned the wheels with motor on.
Good luck!
Good luck!
