nik
P.S.
Does anyone read this thing?
I do! haha I like to see how far it has come since I first met you and saw it!
P.S.
Im reading it.. Just finished catching up on all your progress. I ended up wiring in a switch that controls the computer only. It wont start or die with just the key. The key powers all the accessories and the switch powers the computer. Also very effective incase of a rollover. Were you able to get that solved?
It is still losing all power and backfiring under quick application of throttle or under load.
That and the 1200-1500 rpm idle says something is not right. First try a different tach to verify the idle speed. Some tachs are not very accurate at low speeds. Then see if unplugging the IAC will bring the idle down. If it doesn't you have a vacuum leak or the idle stop screw is set too far in. IAC can be very dirty inside also.
I have got a ton of products in the tank, not a major improvement but there is some. I'm going to pull the plenum and the injectors.
Orielys said it's not throwing any codes at all... weird and I don't believe them.
Anybody know a good article on injector cleaning and testing?
hood shocks "OCBR raffle ;D"
Also added power brakes, got the kit off of ebay for 150 or something with the braket and booster. Makes me wonder how I did it all that while with bad manual brakes.
i need power brakes too my leg gets tired
Super happy when I have a cheap mod that works great! I got this bell Bike brake kit at a sports store for 11 bucks and it had all the parts I needed to use with my 2bbl for a SUPER smooth hand throttle mounted on my shifter.
http://www.amazon.com/Bell-Bike-Cal...1378742378&sr=1-5&keywords=bell+bicycle+brake
I drove almost all the way to work without using the gas pedal!
