NC-Fordguy
I've noticed alot of rattling of the twin stick shifters for a while then tonight I cranked up the bronco to move it into the shop and the truck violently started to shake while in park after giving it some gas-the more gas given the more it shook.
I figured the balancer was the problem...looked good while running
Guessed perhaps a bearing spun in the engine...vacume guage reads steady at 16 inches with a slight tick of the guage(always reads this from the cam) Oil pressure mechanical guage reads 60 when cold and 40 when warmed up, typical readings over the years.
Giving the truck gas while sitting in park I noticed a knocking sound at the bell housing and a spark every now and then
Removed the inspection cover at the bell housing--all 4 bolts for the torque converter are loose. 3 tighten up fine. 4th bolt will not tighten, just spins and it's evident it was hitting something with all the marks on it.
The shaking was not as bad after tightening the 3 bolts but still noticeable
So I'm thinking pulling the tranny and replace the torque converter??
Is this the thing to do and what about the flex plate? Could this have been warped or thrown out of balance from the loose torque converter?
Anything else to look for?
Suggestions most welcome
