Diff oil change and a stupid move.
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
Well, TOFIC did it again.
changing the oil in the front diff and was using a syntec gear oil bottle with the narrow spout to dispense the oil. Had the little plastic cap on the bottle and when I went to put the oil in the diff the little cap fell into the diff. RATS!!! and other 4 letter words!
my question is, will the little plastic cap hurt anything or should I take the thing apart to get it out??
TOFIC
HoosierDaddy
What about after the gears chew that plastic up , can it harm the bearings if it gets lodged it the wrong place?
Worst case if he goes in after it ..... costs him an extra bead of sealant on the diff cover.
Worst case if it stays in there ... ????
Ranchtruck
I've drained diff oil into a ziplock bag, welded up the spiders, packed the bag back in, and thrown the cover on.
There is nothing left of the bag after a few miles of driving. With the pressure and the sliding forces in the hypoid gears, the plastic doesn't stand a chance. If it was the tranny, where you only have helical gears and synchros to get jammed, I'd say yeah, fish it out if you can. A diff? don't worry about it.
Deano
Did it about 4or5 yrs ago took it apart Not to long ago to check it and never found a trace of it so I wouldn't worry about it !
Just put a clear cover on it and watch the carnage! ;D
Although, I'll bow to superior intellect, but I sure don't like the idea of leaving even a piece of plastic where it don't belong.
Knowwhatimean?
KyleQ
Gears and lockers hold up fine when a little water and mud get into the from the breather, plastic will probably be a welcomed foreign material :)
I've used a gear oil pump backwards in a TTB D50 to pump out old oil and I found a nasty surprise of sand, mud and water in it... Had no idea - didn't give me any troubles whatsoever...
Devin
Bronco Kineticist
Yeah, definitely save yourself the 10 minutes of time. %)
bax
Old Member
I agree here. Go get the dam thing. Pop the cover, catch the oil, seal the cover , put oil back in.
Well I already made the sandwich. I'm not going to take the top slice off now just because I forgot to unwrap the cheese. WTF?
KyleQ
North worth the time - and 10 minutes? I don't think so, RTV should set before adding fluid again. Not worth the mess - it won't do anything, if you are worried about a plastic cap in some hypoid gears don't even think of taking your Bronco off a paved road...
Devin
Bronco Kineticist
Wow, and I thought I was lazy. And I stand by my 10 minutes of actual time that you are really doing any work. I guess that is some pretty damn hard work letting the RTV set up. Damn hard work. %)
