Does anyone sell a caliper rebuild kit?
T4x4R
Powder-coated my calipers and need to put new internals back in. pistons, seals etc. Anyone sell a rebuild kit or know part numbers? Thanks
T
T4x4R
they were a front disc upgrade kit from the PO. best guess ive gotten from nappa is maybe chevy calipers? They didnt know other than that. They look better now! just dont work....
tasker
all knowing of nothing
NH
DIFFERENT bores, will need to find out first
T
T4x4R
heres some pictures
looks like the bore of the piston is 2 3/4"'s
EPB72
Pleasant Hill, CA
Yep gm calipers ..Id start with late 70 's early 80's blazer/ 1/2 ton pickup applications ,,raybestos or Carlson should have kits easily found ,,,also there are rubber bushings where the slide pins are and they are in a separate kit
T
T4x4R
thanks! Ill post part numbers once i get them. Cheers
Pa PITT
Stephenville TEXAS
... i'M GOING TO SAY any of the Good Parts story's will have a rebuilt kit.
Now I'd never rebuild a caliper . you buy rebuilt one.& Get a warranty . as the rebuild kits some times cost as much as the ReMan caliper .
... Napa & Carquest. Maybe Oreally.
Timmy390
Conway, AR
X2.....I would not rebuild....buy reman and have a warranty......
Tim
Not unless you're sure whatever manufacturer's parts were used were the later calipers.
By far the most common Bronco conversion is the pre-'76 calipers. So I would use '75 as your go-to numbers first.
For all I know the rebuild kits are all the same, but the calipers changed in the late seventies in some aspect. I just don't know the details.
