76,
I guess I am. The parts seem to all be kind of iffy. The harness is old and needs to be modified, the computer is old and may need some new capacitors, the injectors are old and may be plugged, the labor involved in changing the intake manifold out, plus finding the right upper and lower.
Frankly I think you're trying to talk yourself into something. Are you not very mechanically savvy? Is that what this is all about? MSD, Howell and other aftermarket 302 EFI systems will not outperform stock sequential port, mass air EFI dollar for dollar. They only become viable when you start to exceed 300 HP on the stock setup.
Swap the whole engine in. I don't get why this is so hard for you to understand. A 5.0 has likely has better stuff than your carbed 302. You also have a high likelihood of swapping to a different cam in your 302 due to the difference in firing order. It's far easier to simply swap the engines across.
Car ECUs are solid state - they do not have 'wearable' components. Do you even understand what is inside an ECU? As far as a harness, you don't have to rework one. There are 5 connections to make. That's it. I have 4 Mustang ECUs in my possession - never picked up a used failed one. Red herring.
I've never had a plugged injector with a Mustang engine. I've never had a bad sensor, nor a bad component. The only things you would be wise to buy new are O2 sensors.
If I buy the msd atomic, I just need to install it in place of the carb.
It's a batch fire system with no ignition control. Spend $3500 and get a glorified TBI. DUMB.
Seems simple enough. No need to worry about chasing old gremlins.
You're kidding right? No tuning necessary with a 5.0. It was tuned from the factory. Wire it properly (only needs 5 wires to run) and be on your way. I have 3 5.0 MAF EFI vehicles right now, so I think I know what I'm talking about.
So if someone sold me all the parts for 1500, why not spend a bit more and get all new gear with warranty and tech support?
Maybe you should stick to new cars.
Is that what you mean makes me lazy?
You can't even take the time to look on Craigslist. That's lazy. I never go to wrecking yards. I work full time in an office, travel for weeks at a time and still manage to be able to source parts in the general area of my house. I stand by the laziness assertion.
The ad says no harness. So add another 500 for an aftermarket harness? That's $1000.00 right off the bat.
Yes, a brand new aftermarket harness that placates your lazy streak and labels the wires for you. No schematics necessary. If you are afraid of the stock harness, this is the obvious choice.
You're trying to convince yourself that the MSD will run better and be cheaper. You're wrong. You will end up trouble shooting that thing far more than a stock EFI system and end up spending 3X the amount as a stock EFI. Stock A9x computers will plug in, and fire right up like nothing every happened.
