I’m wrapping up a long winter project to convert my flat-tappet 302 over to Mustang EFI with Explorer serpentine front-dress. I was pretty deep in this project trying to do too many things at once and it feels good to finally be close to finished. The project included; EFI swap with Explore upper/lower intake, Painless EFI harness, braided fuel lines, 23Gal tank w/internal pump, Explorer front-dress with 4G, Saginaw steering pump, high-flow water-pump, new timing chain/gears, aluminum radiator, electric fan with controller, and I rewired all my accessory switches and installed a compact sub-woofer.
Anyway, I’m at the point of the first startup and not quite sure what I should be taking into consideration. A few random questions I have:
That’s about it. Fortunately this 302 was fully operational prior to the conversion, so at least I know the motor is good and functional.
- I manually set the timing at 10 degrees BTDC. At some point I’ll need to run through the SPOUT procedure to set correctly. Does this need to happen immediately on first start?
- Same deal with the TPS setup. I know I need to run thorough the procedure to set TPS minimum voltage, does this need to happen immediately?
- I changed my PS pump and added a larger cooler. I did fill the cooler when installing, but I need to somehow prime the PS pump and bleed the air out. Will this happen naturally or do I need to cycle the steering somehow?
- What should I expect from the pressurized fuel system? Will it constantly cycle fuel with the key on before I start the motor? I would like to charge the fuel system up and let it run before first-start to check for leaks, etc.
- How do I bleed trapped air out of the coolant system? I installed a new radiator and had the block stripped down. Lost a lot of coolant and refilled best I could but I know there’s going to be air trapped inside the block. Will this naturally vacate?
- When I run through the KOEO, what codes should I anticipate? I’m not running an EGR but I do have an “eliminator” plugged into the EGR pigtail.
