In installing my Explorer front serp setup, I neglected to grind the back side of the bracket at the idler pulley for TFI plug clearance. Everything is installed and painted nice so I don't want to hack into it now. I had a thought.....instead of setting base timing at 0 and then advancing 10*.....wouldn't it be easiest to just drop the distributor in with the balancer at 10* for #1? If so, then I will only need a little bit of adjustment either way.
I have done this already, but just wanted to make sure I wasn't missing something by doing this. When I dropped the distributor in, I put the tfi plug about half way thru it's available arc so I have adjustment both ways. I then noted where #1 is on the cap and will place wires accordingly. Anything wrong with going this route vs. making a mess by grinding the back of the Exploder bracket?
