A few people mentioned a "connector". I have three individual wires going to the unit. I replaced them directly in the same locations on the new unit as the old. The unit is a new motor craft unit. The old unit was replaced due to headlights dimming after about five minutes of use. They would dim, then go out completely. After turning them off and back on, they would work momentarily.
So, I disconnected the battery, removed unit from the inner fender, removed three wires, placed three wires on new unit, bolted new unit to inner fender, connected negative terminal. I then ran the vehicle at idle for about fifteen minutes, monitoring headlights. Headlights worked great. However, I put about 80 miles on it after and it ran the worst it has ran since the build. Stumbling at low reva under acceleration, low power at low revs, stalled at idle neumerous times.
I have not swapped the old unit back in yet to see if it remedies the poor running or low voltage.
