Engine building questions
broncoman82
Blairsville Ga.
I am currently in the process of re-building my 351w roller. I want to up grade the heads to these http://www.summitracing.com/parts/fms-m-6049-x307/overview/ and also change the cam. I guess my question is how much cam can I go before I run into having to change push rod length. My plain is to keep the pedestal style rocker arm setup. The engine is out of a 1997 ford f-250 truck and has 87,000 miles on it. I am not going crazy with the build I just want to put a little lopy cam in it and still keep the down low torque.
Mountain Ram
Recovering Masshole
Abingdon, VA
New cam, new heads... Simple answer is to buy a push rod length checker and make sure they are right the first time. The tool is pretty cheap from Summit and they ship push rods quickly. Of course you have to assemble the motor to check pushrod size. It really is the right way to do it- eliminate the guesswork.
Fairlane514
Houston
See if Summit can supply you with the spring pressures on those heads, that way you will know of they can handle your new cam profile.
rguest3
In a Roller 351w with those heads i would recommend a Comp Cams XE258HR-12, or the XE264HR-12. Either way, get the SK-Kit with Matching Lifters and Timing set. With Your Rockers the Complete Heads have everything else less Push Rods.
As stated, measure for Push Rod length after assembly.
bax
Old Member
All good info here. everyone here gets a gold star and a "way to go!"
I can give you the "way to go" but I dont know where the gold star is coming from.
73azbronco
Get the pushrod checker to verify, but I bet while talking to the tech you can order the heads, cam, pushrods all at the same time. I even bet you could reuse the original pushrods. This way you have a new set ready, the original set if needed, and a checker to verify, return what you don't use, or worst case, order what you need.
I would recommend spending the extra $50 ($25 per head) and get the trickflows.
I think they are. Now if it was $200 a head more, maybe not. But only $25 a head more, I would get them again. With a mild flat tappet RV cam (way under cammed for what the head could do) and a port matched Performer intake it had good idle and would pull through 6000 RPM in a 351. That engine was built back in '99 and I sold the truck, last I heard that engine was still running strong with nothing more than updating the throttle body EFI to something newer. Anyone who ever drove that truck just got a big happy grin on there face.
rguest3
Most of the Aluminum Heads with the smaller 165-178cc Intake Runner range (Velocity=Torque) will be a very nice upgrade in the 351w with a mild cam.
Not sure if the Trick Flows will require different Pistons?
Using your Stock Pedestal Mount Rockers narrows your Head choices a little though. Might consider Heads with Stud Mount and get the rockers to match???
Trickflows will work with stock pistons. If building a high compression engine there are special pistons available for them. But generally don't need them. I was running 11:1 compression on a long rod engine (more piston dwell at TDC) on a set of stock replacement 302 pistons. If I went with a radical cam (high RPM, .600+ lift, not enjoyable on the street) I may have had some valve clearance issues. Those heads were initially developed as a replacement for 5.0 mustangs with a stock bottom end.
bronconut73
This is advice you don't get out of the Summit catalog.
That's why we listen to old timers like you 'buck....
