Caster was -1 and -8. Rear sits maybe an inch higher. Same size tires I actually took out the 2 1/2 in lift in back and put in 1” lift. Double checked bushings. Ordered Tom’s radius arms with 4 deg built in. Hope this helps.
I’m not sure what the caster was before I installed the bushings.2nd request: What’s the pinion angle?
You can get a very good approximation by measuring the diff cover angle as well.
If you were at -1, and you installed a 7 degree bushing and ended at -8…that does not bode well for your bushing installation.
But the cover angle will answer it.
-1 on one side, and -8 on the other side?Caster was -1 and -8. .
Not sure on pinion angle.2nd request: What’s the pinion angle?
I didn’t get an alignment before installing bushings.Not sure on pinion angle.
Still won't fix a twisted axle housing.How about with the radius arms with 4 deg built into
He doesn't have 7 degrees of cross caster. I couldn't put 7 degrees of cross caster in a welded wedge Bronco D44 housing if I tried. There just isn't enough tube between the radius arm and the knuckle to get there. Even if you spun the rosettes out of the center, the radius arms would bring the cross caster back to within a degree or two. I remember when @lars and Jim Cole were playing with wristed radius arms and then somebody built a wristed housing. and even then...the knuckles followed the radius arm.You are not fixing 7° of cross caster on a beam axle with bushings. Not going to happen, the axle is way to rigid for that to happen.
Suggest you post the alignment sheet
So no, unless somebody did half a cut-n-turn...it just didn't happen. But I'll leave it to you guys to figure it out.
@ksagis That's gonna be only way to troubleshoot this. I'm out.
That tells me measurements were done after bushings were installed and the results were -1 and -8.I didn’t get an alignment before installing bushings.
