bannind
- Mar 24, 2005
- 612
So I put a new aero tank on the rig with sniper fuel injection. I now have a persistent gas smell in the garage that requires me to leave the door cracked open. The sniper unit is actually working well and starts up immediately, leading me to believe that there is pressure in the supply line and I have no leak there.
I installed the tank with the epoxy on the fuel pump per the instructions from aero tank and believe I have everything tightened as expected. Even after the rig sits for a few days, when I remove the gas cap there is the sound of pressure being relieved. That leads me to believe that everything is tightened and sealed correctly between the tank, fuel pump, return line and fill connections.
Is there any way I could be getting the smell from the Holley sniper setup on the engine? I have a crappy air cleaner, not sure if that is playing into the mix. Just looking for suggestions before I drop the tank and run all new lines.
Setup - Aerotank with explorer pump, holler efi lines with external hp filter.
Thanks,
Dan
Thanks,
Dan
