68ford
- Dec 26, 2004
- 2,710
What were your numbers?
I think a lot of people have seen higher numbers with thick oil and lower numbers with thinner. Some members have been concerned about low pressure (maybe you posted up about that in the past?) but this is the first I remember where it's gone above and beyond normal from using what is still kind of a normal oil.
Then again, did someone comment that this is a new engine? Maybe the tolerances make a bigger difference here then.
More pressure could be expected from 20w/50 for sure. And maybe even by going from just 10 to 15 like the OP did. Just not double the pressure, from 40-ish to 80, with the same oil many here are using without seeing that extreme.
But he did say in the first post that his 10w oil was Royal Purple too. Maybe his previous readings were falsely low? And maybe his current reading of 80 is what he would have had with another brand of 10w oil.
Guess the only way to know anything for sure is to first verify pressure, then try different oils and filters to see how things change.
It is physically impossible to go from 40 psi to 80 psi idle while going from 10-30 to 15-40. Going from 0-20 Mobil1 to straight 50wt racing oil would not take you from 40 to 80 at idle. I run 15-40 delo most of the time, but before I raced last time I put in 50wt Swepco, oil pressure maybe 3 to 5 psi more cold start. Aft that no different. It's noticeably thicker coming out of the bottle.
