Farrell Martin
After plugging away on my truck for a few weeks on various projects, most recently was new timing chain and gear set, I got it all buttoned up and got it running. Worked the timing and idle mixture screws to the point where it was running better than it has since I owned it (just a couple of months). I decided to take it for a short ride, maybe 3-4 miles and see how she did. I was near the end of the test drive and was about a mile from home when I started to smell burning oil. In short order, smoke was billowing out the back of the truck. I was only about 1/4 mile from my home and so I just idled it into the driveway when the motor started making a god awful grinding noise. I shut it off immediately and jumped out to look around. I crawled underneath and EVERYTHING under there was dripping with oil. I don't mean a nice coating of oil, I mean it was dripping from everywhere. After crawling around underneath with engine degreaser and some towels, I traced it to the oil filter. I removed the filter and it appears the rubber seal from the old filter I had just replaced was still there. I guess it had stuck to the block when I removed the old filter. So when I screwed on the new filter, it felt like it had seated, but was from from it.
So, on my little test drive it appears that I pumped basically all of the oil out of the motor and starved it.
I got up thus morning and filled it back with oil and fixed the oil filter issue. But, she won't start. She turns over and sounds vary labored and makes a periodic thunk when the starter is held on.
I feel like I have been punched in the gut. I bought the truck and had budgeted some funds to improve it and make it my own. I have worked on it over the last couple months and was finally done with the improvements and ready to start enjoying it when this happens. And of course, the budget is dried up. Out of disgust, I just pushed it into the garage and shut the door.
Total bummer - F
Total bummer - F
