thanks guys for in the encouragement! I promise it definetly helps after a long night of grinding spot welds!
update 9:45 pm alabama time
here is a few shots of the JBG full bed panel, and the #4 rail underneath it. I drilled the holes to plug weld thru to weld the bed rail to the bed panel. Then I grinded the drill debris down so it will lay flat when I weld it down. The only problem I had with the JGB panel is that the #4 bed support rail wouldnt line up because of those two small brackets on each side in the middle. Picture #4 !
enjoy!
#1 old bed panel with old bed support rail still tack welded on (major rust)
#2 new JBG bed panel with/bed support rail called #4 rail in their catalog
#3 Where the rail will have to sit about an inch back from origional since these little brackets are in the way (I'm guessing they are seat belt brackets) they are pictured in #4 picture
#4 the brackets I spoke of in #3
#5 channel drilled and ready for spot welds to be added thru plug holes to bed panel
#6 drilled and ground plug holes waiting for the welder
#7 back seat hold down nuts from under side of bed panel
#8 WTH is this black mass? possibly a transfer case???
over all I think the JBG bed panel is an excellent piece. I'm just guessing but did all broncos in 1970 have a rear seat? Would they have left seat belts out on rear seat if it didnt come with a rear seat? I dont remember mine having these brackets!........made a short night of it, more to come! enjoy
