BoureeOne
I think the biggest issue he was or is having , is thinking that the front hubs and the transfer case shifter have anything to do with each other... Your transfer case shifter should have markings on the handle, 4 of them, 2H, N, 4L, and 4H... Understand this, no matter what you do with the front hubs, locked or unlocked, the transfer case is going to do just what the shifter handle says... In 2H, only the rear drive shaft is going to send power to the rear axel. N, no power is going to be sent to either axel. 4H, power is being sent to both the rear axel and the front axel ( notice I am saying axel and not wheels ), even thought the power is being sent to the front axel ( which means the front drive shaft is turning, and the front axels are turning inside the axel housing) the front wheels will not have power to them until you lock the hubs. Same thing for 4L. So yes, you are correct, you can have basically 2 wheel low if you put the shifter in 4L, and you do not lock the front hubs. As stated, always leave the front hubs unlocked when you are in 2H. Good luck. Hope the light just got brighter....
