I am going to take the pan out and see if a friend of mine who runs a machine shop can bead roll the pans for me. I am going to cut out the DS pan fit it, then take it down to him.
UPS came and I rushed out to the garage and opened the box and started assembly immediately. Had to dig out the old lower cowl section to make sure that I attached it to the right part of the post. I really need to cut out that PS Kick panel so I can attach the other post and lock that cowl in. Had to grind some of the end pieces to square them up.
Next step after that is the section that is on top of the firewall. Was going to keep the old and just weld up new metal where the rust was. That is going to change "since I'm there". Thinking about taking out the air ducts and making it a straight piece like some mods have done.
I'm not sure how that horizontal front piece attaches to the cowl frame. My old one was so gunked up with bondo and rust from an accident not sure if it was done correctly.The reason that I put it on the inside is whoever did the repair before replaced this post and put this on the INSIDE. Just goes to show me that I can't trust what's there. Man I just learned a lesson.
Edit:Ok, after a couple hours of searching, I know what I did wrong. The downward tab goes on the outside of the doorpost and rests against the inner lip. This was driving me crazy. I just learned a lesson, whoever did a repair on the cowl, put the tab on the inside, so that's what I followed. Guess it worked, but man this was making things hard! I know that it looks like it is tacked in, but that is from a spacer I put in there. The frame is just resting on the posts.
