migs Bronco Barn - a chronicle of what's happening at the new place
migs
migs
I pulled the fuel tank, and dissected the homemade hitch contraption from the rear frame rails. It wasn't too difficult to cut through the few poor welds a bit and snap it off. This is the one area of the frame that needs some rust repair attention, but she's looking better already!
IMG_7720.jpg IMG_7722.jpg IMG_7723.jpg IMG_7724.jpg IMG_7725.jpg IMG_7728.jpg IMG_7729.jpg IMG_7730.jpg IMG_7731.jpg IMG_7734.jpg
tasker
all knowing of nothing
NH
Are those one of a kind shackles on that??
migs
migs
Chassis supported so I can drop some suspension components out of the way, getting ready for some metal surgery this weekend....
migs
migs
With the frame supported by the lift I removed the rear shocks and pulled the spring shackle bolts in order to drop the springs out of the way of the frame rail section that needs addressing.
Here is the culprit being tackled today, It's the passenger side rear frame rail. The body mount hole is toast and there's lots of rust and rot through on the inside and outside as well as some cracks.
Luckily the driver's side is in much better condition, that only needs the body mount hole addressed... we'll deal with that easy fix another day.
And here it is after cutting off the spring hanger. You can see that there wasn't too much metal left behind it.
migs
migs
After a little dissection and massaging some new metal into place....
Out with the old...
...and in with the new 😁
IMG_7780.jpg IMG_7781.jpg IMG_7782.jpg IMG_7783.jpg IMG_7784.jpg IMG_7785.jpg IMG_7786.jpg
Looking much happier now. Next up will be welding the spring hanger back on and sprucing up the driver's side.
migs
migs
There's probably still water in there! Heck, just last year when it was here I had to drill drain holes in the front bumper to drain trapped water out
(now where's that headlight picture??) 😉
