migs' build thread - A 1970 Bronco ...an ever evolving project
migs
migs
...and with a fresh coat of paint on the housing. almost ready to go back under the truck for good!:)
Crawdad
nothing fancy on this build, for the axles just brushing on POR15.
will be dragging them over rocks...someday.;D
Well that sounds better than crayons or permanent markers for a paint job. Build is looking good from where I sit. Keep up the good work!
dave67fd
Lookin great B.
Is that a locker you threw in?
Up for doin another one?;D
migs
migs
what could these oddly shaped parts be...........
migs
migs
....they are the finishing touches to my front differential cover armor. :cool:
1/4" steel plate I formed up to fit around the bottom and up and over the ring gear. hopefully will add some protection if a tire slips and the axle comes crashing down.
here it is all welded up.
migs
migs
and after a little grinding and a visit to the blast cabinet.
migs
migs
Thanks guys
thinking I may add a small flush mount pipe plug at the bottom to be able to drain it without having to pull the cover.
migs
migs
just little work on some of the many small things...
media blast then painted.
Crawdad
Looking good B!
I've gotta keep an eye out for those transfer case mount brackets. My frame didn't come with them. I saw a set in eBay for $60 but I want super cheap and within driving distance.
migs
migs
Tonight I tack welded the new lower bearing in my '76 auto column then threw on some new paint. lucky for me the upper bearing and everything else inside the column was in good shape so I saved some time by not having to take it all apart. might have to find a new shifter arm though, the one out of this one is pretty pitted.
