Need quick help on gear oil type?
Blue71
I am changing my gear oil in the front Dana 44 and rear 9" of the '74. Also changing the Transfer case fluid. What weight? If I remember right its either 80W90 in all 3 areas or 80W90 in the diffs and 50 weight in the T-case. How much in eash too???Need help quick cause its draining now and I gotta get home in a few.
Thanks much,
Blue71
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
80/90 in rears and 50 in transfer case but you can go to 30 in the transfer case if it is cold out. 3.75 pints in front not sure about rear. just fill untill it comes out of the side hole.
Blue71
Blue71
Thanks 2Bad. Can I use 80W90 in the T-case? Nobody seems to carry 50 or 30weight here?
Thanks,
Blue71
broncnaz
some people fun 90w in the T-case with no problems the shop manuals say 50W engine oil I know Valvoline makes some usually in a silver bottle
wildbill
Old Bronco Guy
%) %) %) I run the 85-90 in all 3 unites and have had no problems in 90 some thousand miles so go for it good luck.:p :p :p Bill :cool: %) :p
I run gear oil in all 3 as well.
50W is old school. To find the correct 50W (non detergent) would be like finding some alchol based antifreeze. It just isn't on the market.
The new set of tera-low gears also says to run gear oil.
Lets see, motor oil to protect gears, or gear oil to protect gears?
Blue71
Blue71
Thanks guys. I got it all taken care of with your help.
Much Thanks,
Blue71
