slowstroke
Really would like some opinions before pulling the trigger. Trying to get a price to offer for it. I looked at a 75 this afternoon. It going to be my first EB. The truck is a 75 uncut. it has what appears to be the original 302 and an automatic trans on the tree. Is a 4x4 all components are there. the owner has a hard top and a half cab to go with the truck. all the chrome is off the truck but in pretty good shape and is all there from what i could tell. The glass is in great condition. The truck is a new mexico/nevada vehicle.
It has a body lift on it so i was able to inspect all around the frame and theres no rust. There is a tiny bit of rust in the engine bay passenger side near the firewall and the front floor pans have been replaced(very terribly might i say!) trans tunnel is original color and in great shape.. the bed, frame etc are all in great shape. The tailgate isn't original as its a different color but the other panels, doors, are all factory green. Glovebox vin matches door vin. the roof has absolutely zero rust on it. The truck doesn't run ( the gas tanks,battery and radiator are off the truck) but the owner said the motor does run and the trans shifts through all gears. Has front 2 seats in terrible condition no rear.
Im am trying to identify what differential is in the truck. i pulled a tag off the transfer case and the front diff as well. would anyone be able to help identify. What would you offer????
Vin Tag reads
U15GLV64926
WB COLOR TYPE BODY TRANS AXLE
092 8 U153 34 G 18J
Front Differential tag read( bear with me there was alot of grime)
i think it said
3.54 or 3.55 D4TA ACA
picture of the front and rear diff are below.
Front pumpkin side view shown from driver side towards passneger
Rear pumpkin front driveshaft side
Rear diff Rear
transfer case tag reads
30077E-IS
D3TA-&A195 CC
Here is the truck
Exterior
Little surface rust some spots on the gate area are sanded down to metal also a llittle damage on the rear driver side lower
Bed area No rust through just a tiny bit of surface stuff. scratched off with my key.
Engine bay
Patch panel no other rust seen around the area
Fenderwells
interior
Vin Tag reads
U15GLV64926
092 8 U153 34 G 18J
Rear diff Rear
30077E-IS
D3TA-&A195 CC
Here is the truck
Exterior
Engine bay
Fenderwells
interior
