clintonvillian
1. I had to drop my front driveshaft and noticed the joints are a little dry.
It seems I need 6 1310 spicer joints to do all of them. Should I do the CV joint as well? And is there anything I need to know before I replace it?
2. The next question involves the door striker backup plates. I have one bolt that is stripped and just spins. Both bolts on the opposite striker won't budge and they need adjusted.
Any tips on replacing these without having to do major surgery on the pillars?
I have tried an impact and socket/rachet with screw driver tips and it just snaps the heads of the bits off. Heat has not helped either...
