Rear shock mount drain
joshua
Should I slice this corner off so it has a place to drain?
Yes, I would. The factory had a very good reason for putting it there. So unless you have a hole drilled just in that area to the inside of the frame, to allow drainage that way, I would chop off the corner.
Do you still have the old mounts to compare to?
joshua
joshua
Yep. I did look at them, well what’s left. But I could tell the corners were open. I think I’m just gonna open the corner that points straight down tho.
The other corner points right at the wheel. I think that will just help it fill with junk faster
I agree and always felt that way too.
Never bothered to close up the extra hole, and I don’t live in a moist environment anyway so I wasn’t too worried.
But I always thought that the single drain would reduce the instance of water and mud intrusion. And still allow you to fire a hose up there under pressure during the summer to wash out any debris or insects that did get up there.
Apogee
Tangent, OR
You could always pumch a decent sized hole in the outside surface of the bracket as well, that way you can blast water into the pocket and out the bottom drain hole as needed.
joshua
joshua
I made it just the right size for my air nozzle to fit up it and make a good seal with the rubber end to blast it out
