Zinc additive for the flat tappet cam. Unsure if it was broken in before or what cam is in it. Just run a bottle of zinc for now. Won't hurt anything, good chance at saving stuff.
FYI the zinc was removed from normal oil used in modern cars for emissions reasons. Won't hurt an old engine by running it. Once broken in you don't need to add it anymore.
As for the advice on making 5k passes on a fresh engine, 4k is a lot better choice. You may not have the valve springs to hit 5k if it was a stock build.
