Speedo Gear What color after gear change?
svastano
Pulaski, PA
So group I pulled the trigger and had my gears changed from 3.50's to 4.56 I am running with 35" tires. I changed the speedo gear out when I switched t the 35" tires and now I have to switch again but to what color this time? Thanks in advance. And I thought I could go back to my original gear but I can't find it anyway.
69_Sport
The easiest way to determine what gear you need is to drive it with the current gear. Take along a cell phone or a GPS and compare the speed you see on the GPS with your speedometer.
Let's say your speedo says 55 mph, but the GPS says your actual speed is 50 mph. So you need a gear that slows down the speedo. How much?
55-50=5. So it's off 5mph at an actual 50 mph.
50÷5=10. It's off by 10 percent.
You need a gear that will slow down the speedo 10 percent.
Count the teeth on your existing gear. More teeth will slow down the speedo, less teeth will speed it up.
Let's say your existing gear has 16 teeth. Ten percent of 16 is 1.6. 16 + 1.6 = 17.6 teeth on the new gear. Round to the nearest whole number (gears won't have partial teeth!) or 18 teeth.
It's a simple proportion. Determine how far off it is now and the calculation is easy.
svastano
svastano
Pulaski, PA
Thanks for that info.
As for the half tooth rounding, I recommend rounding down if it can go either way. That makes the speedometer run slightly faster than actual. Safer than slightly slower than actual.
svastano
svastano
Pulaski, PA
Good advice! I don't need the Popo behind me with lights on!
