Surprise under valvecover
ribbits
Had a valve that started tapping a bit.... Pulled the cover and this is what I found... Doesn't appear to have any abnormal wear on the push rod or rocker arm, and the push rod passed the rolling on a flat surface test.. Didn't appear to have any thread locker on the nuts?? Think it will be OK just to re-position it and then re-adjust them all with blue thread locker ??
DJs74
From the photo, the rocker arm nut looks to be threaded down the correct amount so there is some other reason that the rocker arm came off and is no longer positioned on the valve tip / spring correctly.
You should not need any thread locker, the rocker arm nuts have a feature built into them that creates resistance against the stud threads to keep them tight and from backing off.
Check the spring real good to make sure it isn't broken - other than the spring, there could be a problem with the nut or stud, the pivot ball, the lifter or the cam lobe that would result in the rocker arm getting lose enough to come off the valve tip.
Have you tried to loosen the rocker arm nut and does it still have resistance? Did you try rotating the rocker arm back into the correct position with the nut in the position its in now? Just wondering if the rocker arm stud might've pulled out of the head a little bit... depending on the age and miles, its possible. On one of my 302s, I converted the valvetrain to adjustable rockers with roller tip rocker arms and to avoid the studs from pulling out, I drilled through the rocker stud boss with a 1/8" drill bit so I just caught the edge of the stud and drove Ø1/8" roll pins in all 16 studs.
DJs74
pennyduke
Stafford
It looks like the rocker stud pulled out. Hard to tell from the picture. Lay a straight edge across all the studs and see if that one is higher. I see this all the time on Chevy motors. Never had it happen to a ford motor yet...
Wrong parts. Need either rail tip rockers or pushrod guide plates. I see neither.
bmc69
I have a set of the "rail tip" roller tip rockers and they look just like that from the top side. Does need to be verified that those are too, though....
Steve83
I've seen this (and worse) caused by ethanol in the gas. (Yeah, I didn't believe that at first, either.)
Engines built for leaded gas use the lead to lubricate the valve guides. Without it, some other additives in the gas are supposed to do the job, but ethanol causes varnish in the guides, which causes the valves to stick. That causes slack in the valvetrain, and the pushrod jumps out-of-place. It happened to my lawn mower (also due to grass building up in the fins around the pushrod journal) and my g/f's MGB.
To prevent it, either buy ethanol-free gas (search for that website, or install an app like PureGas on your phone), or use a pour-in fuel additive like lead substitute or MMO (top end lube).
B RON CO
Statesville, NC
Hi, I'm with rail rocker or guide plate. Ford used rail end rocker arms to keep the rocker arm located on top of the valve stem. To install guide plates the pedestal must be machined to compensate for the guide plate thickness. and threaded for screw in rocker studs. Good luck
pennyduke
Stafford
When you say rail tip rockers, Is that the same as self aligning rockers? The rocker has a lip that comes down on both sides to prevent it from coming off of the valve stem. If that is what he has, I would say that the stud has pulled out. It could be a number of things but I would check that first.
savage
Bronco Nut
Renton
I'm with the stud pulling out, but I am wondering if that rocker has a edge past the roller to hold the rocker (rail rocker).
Bronco Junkie
So Cal Broncos
hi, i'm with rail rocker or guide plate. Ford used rail end rocker arms to keep the rocker arm located on top of the valve stem. To install guide plates the pedestal must be machined to compensate for the guide plate thickness. And threaded for screw in rocker studs. Good luck
x3................
blubuckaroo
Grease Monkey
Ridgefield WA
In that application, rail type rockers are necessary. But, from the photo, you can't tell weather the rockers are rail type or not.
I really doubt though that those are the non-rail type. It would be tough to keep them on track even just during assembly. Here's the difference...
The photo on the left is the rail type.
DJs74
You guys are right that the self aligning rockers are needed but don't you think if it didn't have them, he'd have more than just one off by now. If that is the case and the rockers are wrong, the original poster should head to the closest store and play the lottery tonight because that is some luck right there.
I had a set of rockers from Comp that look identical to the ones in the photo and they were self aligning, the roller was recessed above the walls of the arm... guessing his is too but that's just an assumption at this point.
DJs74
gotdads68
At least it was caught before it kicked the keepers and dropped the valve.
ribbits
ribbits
Thanks guys for all the data, I've learned a lot here so far.. Looks like I've got positive stop studs, and when I removed the stud nut I'm thinking it had nothing like 20 ft lbs of torque on it? I measured the push rod at 6.883" and I know it has an "other that stock" cam but not sure just how aggressive.. The build sheet says a 275 Comp cam?? I do know that the rockers are Comp cam 1.6's but this truck has been full of surprises, some pleasant and some not do pleasant.. The push rod was leaned over but not rubbing the edge of the hole cast in the head.. I rolled the push rod on a very flat surface and it took off and seemed to roll very true with no wobble or humping.. I laid a machine tool straight edge across the top of both the adjacent studs and it doesn't appear to be any longer than those, but my eyes ain't what they use to be and had at least 3 different lights shinning on it at the time? When using a longer straight edge to span more studs, I get interference from the rocker arms I guess due to their position.. I'm pretty sure they are rail rockers but will post a pic shortly so maybe you guys can verify this.. The push rods are hollow so I'm assuming they are hydraulic? I'm leaning towards just pulling the other valve cover, removing the spark plugs and going through the procedure and torque the nuts to 20 ft/lbs and maybe put some blue thread locker on the studs (what could it hurt) .. Then again, maybe I should do the "Dry erase" marker method to verify push rod lengths simply so I will know what I have here regarding cam, heads, valve seats etc..? Thanks again..
pcf_mark
That appears to be the correct rocker type that is good news. I would get a NEW set of nuts and tighten them down to 20-25 ft-lbs. Put a straight edge on the top of all the studs and then the valves to be sure everything is reasonably in line.
blubuckaroo
Grease Monkey
Ridgefield WA
The wrong pushrods wouldn't have caused this. Sure it will affect the life of the valve train but I'd say there is something else going on here.
You know what? even a stuck lifter could have caused this valve to jump track.
