- Mar 1, 2013
- 433
What started as a coolant leak(rusted through water pump bolt) and harmonic balancer replacement has quickly rabbit holed into a timing chain cover (damaged trying to remove what was left of the rusted water pump bolt) and timing chain replacement. My problem is that I didn't have the motor set to top dead center when I started this project and now I have everything broke down to the timing chain. Can I get to TDC from where I have the project now (Picture) or will I need to reassemble with the chain cover and balancer back on to get TDC easier? Fluids are all drained too. I wasn't planning on going this far but here I am and hope I haven't gotten myself so far in the weeds that I can't find my way back and end up with bigger problems. Any guidance, tips, or general direction is greatly appreciated. I wasn't planning on doing the chain until I got the cover off and saw that it had quite a bit of slack
