jcwalsh1
My Ignition Module failed and I ended up replacing the distributor cap, rotor, plug wires, etc before figuring out the problem. I also bought a timing light which could be making the situation worse.
I measured #1 TDC with a cylinder stop and it showed about 4 degrees on the harmonic. The rotor was aligned with #1. I had already painted a white line at 0 on the balancer.
When I move the distributor to 10 degrees TDC with the light the engine runs really rough. When I move the distributor clockwise it gets smooth just as the vacuum hits the coolant hose. At 700 rpm vacuum is in the green but the timing light shows 35 degrees TDC.
From the PO notes:
Engine bored .30 over
RV Cam, 2 stage over stock
Oversized valves
Headers into glasspacs
Is the distributor off by a tooth? I tried to do a test drive yesterday and it was backfiring under load.
Any help would be appreciated. I have read almost every previous timing post. All of the spark plug wires are correct. Firing order 15426378.
From the PO notes:
Oversized valves
